Clicking sound on passenger side?
ALF
  • 2005 CHEVROLET CAVALIER
  • 62,000 MILES
There is a clicking sound on passenger side coming from near fan
Monday, March 19th, 2012 AT 10:49 PM
SATURNTECH9
  • 30,870 POSTS
Try turning the recirculation on and wait and then turn it off. See if the noise changes?
Monday, March 19th, 2012 AT 10:52 PM
ALF
Changing any of the settings on the heater or AC does not effect the noise.
Monday, March 19th, 2012 AT 11:00 PM
SATURNTECH9
  • 30,870 POSTS
Your going to have to trace it down to its source and we will go from there.
Monday, March 19th, 2012 AT 11:05 PM
AMM7467
Sounds like the motor that controls the recirculation when it starts to go bad it wont cut off it just keeps going a quick way to find out if this is the problem is to take the piece of plastic off of the front of the windshield where your windshield wipers are and then look in the little vent and see if you can see the piece of plastic that is moving it will be on the passenger side I had the same problem until I took out the passenger airbag and unplugged the motor in recirculation the pic is the sensor and the flap that is probably making the noise
Friday, March 23rd, 2012 AT 7:51 PM
SATURNTECH9
  • 30,870 POSTS
Also I have had customers with broken recirculation doors cause the same thing to happen where the recirculation servo keeps running.
Friday, March 23rd, 2012 AT 11:15 PM
ESTAN1980
  • 4 CYL
  • FWD
  • 98,000 MILES
My question is when I start my car a very loud clicking noise is coming from under my dash board. It is not in the dash but I believe the back of the engine near the dash. The car seems to be fine when engine is on but just that noise. I am hoping it is not an electical problem because it sounds like something unplugged or fell apart. My friend who drove the car says whe can smell a faint smell of burn. Please if you can give me some sort of an idea before I take it in to maybe see what I am looking forward to fix.
Tuesday, September 29th, 2020 AT 11:41 AM (Merged)
RHALL77
  • 3,361 POSTS
Sounds lik there is a relay acting up. Reach around under the dash when it is doong it to pinpoint the click. Let me know what you find and Ill see what I can do to help
TPNICH
  • 2004 CHEVROLET CAVALIER
  • 2.2L
  • 4 CYL
  • FWD
  • 56,000 MILES
The control cable for heat control was bent, straightened it now clicking noise in fan area what is this
JOHNNYT73
  • 924 POSTS
Could be the blend door actuator
TPNICH
Is this in behind the fan motor?
JOHNNYT73
  • 924 POSTS
Hmm. Im looking at photos of the hvac assembly (what I can find). I think the only motor you have is the recirculation motor. Its located on the very top right of the assembly. You can try and drop the fan motor just to maker sure it isnt something caught in the fan making the noise.
TPNICH
Thank you
JUAN P RODARTE
  • 6 POSTS
  • 4 CYL
  • 146,900 MILES
My 2004 Chevy cavalier started making a loud sound, two different mechanics told me different things, one said serpentine belt and tensioner, the other loose timing chain, it does not make the sound always only about 1 our of 10 times I start my car or less, it is a2.2 engine, 150 k miles.
MERLIN2021
  • 17,250 POSTS
When the sound is present remove the serp belt and start engine if noise is still present it's the timing belt. If noise is gone its the serp
JUAN P RODARTE
  • 6 POSTS
Thanks, it was the timing belt tensioner, it was broken, I put a new timing kit about 2 months ago, thank you
MERLIN2021
  • 17,250 POSTS
Ok.
HEYES
  • 2003 CHEVROLET CAVALIER
  • 4 CYL
  • MANUAL
  • 30,000 MILES
I have a clicking noise in the right side of my dashboard it clicks when I turn the key car does not need to be running to make the clicking noise
  • 108,192 POSTS
Chances are it is a relay.
HEYES
It stops when I turn on the ac
  • 108,192 POSTS
Chances are that is it. Check behind the glove box. Determine which relay is making the noise and see if replacing it fixes it.
