1989 Chevy Blazer 4X4 vaccum
FERLEY22
  • 1989 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 150,000 MILES
When 4x4 is engauged, there is transmission fluid being drawn into the engine via vaccum. Is this a vacuum actuator problem or another booger.
Do you
have the same problem?
Wednesday, March 10th, 2010 AT 5:49 AM
JACK42
Could be the vacuum switch on the transfer case.Have any of the vacuum lines been moved or any work done on it? If the vent line is put on the engine it can do that.If nothing has been changed recently, it is most likely the vacuum switch on the transfer case.
http://www.2carpros.com/forum/automotive_pictures/1639_blazer2_1.jpg
Wednesday, March 10th, 2010 AT 7:40 AM
Recommended Guides
