Check engine light on?
TOYOTABOY123
  • 1990 TOYOTA PICKUP
  • 176,000 MILES
I replaced knock sensor and pigtail on my truck listed above four wheel drive 3.0L engine. Check engine light comes on after truck reaches 2,000 rpm's. Check engine light goes out when I take foot off gas pedal. Code 52 does not go away. What causes this?
Monday, July 23rd, 2018 AT 4:42 PM
  • 52,797 POSTS
Good morning.
Here is the test for the knock sensor for code 52.
1. Warm-up engine to normal operating temperature.
Tachometer Hookup
imageZoom/Print
2. Attach a timing light with advance indicator and a tachometer.
Fig. 223 Ignition Timing (10)
imageZoom/Print
3. While operating the engine at 2,000 rpm, check the ignition spark advance and calibrate the timing mark to 0° TDC.
4. Using a wrench or small hammer, tap the exhaust manifold and observe the timing marks.
5. The ignition timing mark should move in the retard direction, depending on the intensity and speed of the tapping.
6. If the timing mark does not retard, turn the engine off and check the wiring between the Knock Control Sensor and the ECU.
Locate the Knock Control Sensor, (on the top, center of the engine block), and ensure that the connector is secure.
7. If no problems are found, replace the Knock Control Sensor and repeat test procedure.
8. If timing still does not retard, replace the ECU.
9. Disconnect timing light and tachometer from the engine.
Tuesday, July 24th, 2018 AT 4:10 AM
VICKRCL
  • 4 CYL
  • 4WD
  • 70,000 MILES
I am having an intermittent problem with the fuel injected truck. It will be running fine, then the check engine light comes on and it shuts down at once. If I pump the gas heavily, I can restart the vehicle, but I must pump the gas until the rpm is high. If I let it go down to idle, it dies. This happens for a few minutes, then it is ok again. It has happened numerous times. I thought it was when it was wet or rainy, but that wasn't the case the last few times. I'm at a loss. Toyota can't find the problem, I had it towed there and it never happened while they had it.
Sunday, November 15th, 2020 AT 9:20 AM (Merged)
Check the fuel pressure if okay -clean out the idle air control valve and test the throttle position sensor-
Try removing the EFI fuse to clear the CEL if not pull the code/s by jumping Te-1 to E-1 in the diagnostic connector-this is your starting point of diagnosis this guide will help
https://www.2carpros.com/articles/toyota-trouble-code-definitions-and-code-gathering-method-1990-1995
MITCHANDVANESSA
  • 3.0L
  • V6
  • RWD
  • MANUAL
  • 98,000 MILES
My light came on, I connected terminals T E and it gave me 4 blinks, paused then blinked another 2. My Hanes book says code 42, no " IDL" signal or " NSW" or A/C signal to ECU. Also no" SPD" to ECU. In conclusion according to the definition on Haynes repair manual, the trouble area is ( speed sensor curcuit, vehicle speed sensor and ECU, PLEASE HELP!
Sunday, November 15th, 2020 AT 9:21 AM (Merged)
  • 108,200 POSTS
That code indicates there is no signal from the vehicle speed sensor. Check for wiring issues at the sensor and if everything is good, replace the sensor.
  • 108,200 POSTS
That code indicates there is no signal to the ECU from the vehicle speed sensor. If there are no wiring issues, replace the sensor.
BOXSTER617
My truck kept popping EFI fuses so I check o2 sensor. When new engine was put in the mechanic never supported the wire going to the o2 sensor. Needless to say the exhaust melted the wire coating on all four wires to the o2. I have repaired the wires and so far no fuses have popped but the check engine light is still on. I unhooked the battery for 10 minutes and check engine light still on. The only thing I can thing that might be wrong in the carbon scoring in the wires from being in the exhaust. Maybe I didn't cut back far enough on the wire before reconnecting. Could this be it? A poor connection of the o2 wires?
Thank you,
Rich
DOCFIXIT
  • 18,828 POSTS
HI
Find test connector near fuse box key on jumper wier from TE1 to E1. Check engine light will flash see diagram on how to read
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_522.jpg
https://www.2carpros.com/forum/automotive_pictures/198357_Grafic_3_133.jpg
Then post codes will advise. Wires to O2 neeed to soildered any increased resistence can cause trouble.
Thanks for donate
Hi boxster617,
This guide can help you
BOXSTER617
**_*___*****_* I think it is 21 then 51.
Does this sound right?
Diagnostic Trouble Codes - 1990
Toyota
11 ECU Power Supply.
12 Engine RPM Signal.
13 Engine RPM Signal.
14 Ignition Signal.
21 Oxygen Sensor (OS) Signal.
22 Water Temperature Sensor (THW) Signal.
24 Intake Air Temperature Sensor (THA) Signal.
25 Air/Fuel ratio lean.
26 Air/Fuel ratio rich.
27 Sub-oxygen sensor signal.
31 Air Flow Meter Signal.
32 Air Flow Meter Signal.
41 Throttle Position Sensor (TPS).
42 Vehicle Speed Sensor (VSS) Signal.
43 Starter Circuit Signal.
51 Switch Condition Signal.
71 EGR system malfunction.
BOXSTER617
I think letting the vehicle sit for awhile is what it needed. I started it up about 2hrs later and no check engine light. I will keep monitoring the CEL but it looks like problem solved. Thank you for your knowledge. I have learned more problem solving skills.
Rich
MERLIN2021
  • 17,250 POSTS
Four wire o2 sensors actually breathe through the plastic wire insulation, o2 sensors are very cheap and I recommend replacing it if you spliced wires. This sensor will adversely affect fuel economy and if it shorts out can ruin the PCM. Very expensive fix then! Once of prevention is worth.
HENRYMESA
  • 1989 TOYOTA PICKUP
  • 2.4L
  • 4 CYL
  • 250,000 MILES
I just replaced light bulbs on the screen, board and when I put eve back light came on and stayed on it does not matter what are you doing. Truck is working fine no problems and is running good, but light is on. I try battery off, battery terminals. When you just put battery on, the light on.
Sunday, November 15th, 2020 AT 9:22 AM (Merged)
TOUGHDIVER
  • 224 POSTS
The check engine may have been on before and the light was burnt out. When you replaced the light bulbs it showed up. If the vehicle has a hard code the light will stay on until fault is corrected. The emissions codes like the evaporated system with have a error and the vehicle will function normally. Regardless you need to check the diagnostic trouble codes and here is how you do it. Turn the ignition switch to on. Do not start the engine. Connect terminals TE1 and E1 of the check connector located near the No.2 relay block schematic is showed below. Read the diagnostic code as indicated by the number of flashes of the "Check Engine" warning light. Normal system operation the light will blink 2 times per second. . Malfunction Code Indication the light will blink a number of times equal to the malfunction code indication with a 2.4 second interval between each code indication.After all codes have been output, there will be a 4.5 second pause.
The code display will be repeated as long as both check engine connector terminals are connected. Hint: In event of a number of trouble codes, indication will begin from the small value and continue to the larger in order. After the diagnosis check, remove the service wire. Please check out the guide and schematics below. Pull all troubles codes and write them down in case they get erase by accident. Start diagnostics in the order each code is pulled. Repair the malfunction and erase and erase the codes.
Here is how the erase codes without a scan tool safely: Cancellation can also be done by removing the battery negative (-) terminal for 10 minutes, but in this case, other memory systems will also be cancelled out. If the diagnosis code is not cancelled out, it will be retained by the ECU and appear along with a new code in event of future trouble.If it is necessary to work on engine components requiring removal of the battery terminal, a check must first be made to see if a diagnostic code has been recorded. After cancellation, perform a road test to confirm that a "normal" code is now read on the check engine warning light. If the same diagnosis code appears, It indicates that the trouble area has not been repaired thoroughly. If you need more information how to diagnose the codes you pull. Please make another post and we will get it for you. Let us know if this information was helpful.
Thank you
Joe Terwilliger
https://www.2carpros.com/trouble_codes/obd2
MODESTOV
  • 155,000 MILES
The engine is a 22R/carb no one knows what the code is. Code that is given is 31.
  • 31,938 POSTS
How was this code retrieved, does it have an OBD connection?
WRENCHTECH
  • 20,757 POSTS
It means "Open or short signal in vacuum switches signal VSW1, VSW2, VSW3" These are EGR solenoids.
COOLHANDLUKE1965
  • 1987 TOYOTA PICKUP
  • 4 CYL
  • 4WD
  • MANUAL
  • 89,000 MILES
Cant Find My "ServiceEngine" Light Doesnt Come On When I Turn Ignition On. Someone May Have Tampered With It? 1987 Toyota Pick-up 4X4 4cyl. 5-Speed. How Do I Find Out For Sure? Also, Where The ---- Is The Fuel Filter On This Thing? The Engine Is A 22R.
