Car cranks but wont fire over
PATRICK HAUGER
  • 1995 CHEVROLET BLAZER
  • 4.3L
  • V6
  • RWD
  • 211,897 MILES
Changed fuel pressure regulator had to remove distributor cause clip that holds fuel lines in flew now truck cranks, but does not fire over, It gets gas got spark. At a loss as to what could be wrong as we have reset the distributor multiple times thinking we did not get in right position, but to no avail.
Do you
have the same problem?
Tuesday, August 9th, 2016 AT 12:54 AM
WRENCHTECH
  • EXPERT
The distributor cap is a little confusing as ti which cylinder the rotor is pointing to. You have to bring the engine up to TDC on #1 on the compression stroke and then align these marks.
https://www.2carpros.com/images/external/84852747.gif
Tuesday, August 9th, 2016 AT 3:39 AM
PATRICK HAUGER
My distributor is different then that one and yes we have it tdc. So unless the lines on harmonic is wrong place we did everything by the book.
Tuesday, August 9th, 2016 AT 6:21 AM
PATRICK HAUGER
My distributor also is not stamped with a six like all the videos.
Tuesday, August 9th, 2016 AT 6:23 AM
WRENCHTECH
  • EXPERT
If you have the flat distributor cap, they definitely do not line up on the outside. You have to look at the inside of the cap to find #1.
Tuesday, August 9th, 2016 AT 6:24 AM
WRENCHTECH
  • EXPERT
If you have a non OBD2 system, you will have the old style distributor and that one should be easy to install.
https://www.2carpros.com/images/external/42407347.gif
Tuesday, August 9th, 2016 AT 6:27 AM
PATRICK HAUGER
It s the vertical style my buddy who is certified said something about being an adjustable distributor should the fuel regulator needed set before install it came with a bit to do so, but we assumed it should be set close enough to run on out of the package.
Tuesday, August 9th, 2016 AT 6:35 AM
PATRICK HAUGER
The last picture looks like mine. I cannot tell if it has two plugs like mine or not, but the rest seems right.
Tuesday, August 9th, 2016 AT 6:37 AM
WRENCHTECH
  • EXPERT
You need to go back to basics and test fuel pressure and spark. This system will not run under 55PSI of fuel pressure.
Tuesday, August 9th, 2016 AT 6:38 AM
PATRICK HAUGER
We have spark just does not seem that it is firing fast enough or maybe my firing order different and I cannot check fuel pressure. Do not have access to a gauge to do it.
Tuesday, August 9th, 2016 AT 6:45 AM
HMAC300
  • EXPERT
Auto parts rents them.
Tuesday, August 9th, 2016 AT 9:40 AM
PATRICK HAUGER
For $160.00 where I am at.
Tuesday, August 9th, 2016 AT 9:50 AM
WRENCHTECH
  • EXPERT
Unfortunately you are just spinning your wheels if you do not have a fuel pressure gauge. Fuel pressure is critical on this engine.
Tuesday, August 9th, 2016 AT 12:35 PM
PATRICK HAUGER
Fuel pressure is spot-on moving on to replacing the distributor.
Tuesday, August 9th, 2016 AT 12:51 PM
WRENCHTECH
  • EXPERT
Spot on? What exactly is the pressure KOEO?
Tuesday, August 9th, 2016 AT 1:06 PM
PATRICK HAUGER
75 at peak when you turn key settles to 60.
Tuesday, August 9th, 2016 AT 1:15 PM
PATRICK HAUGER
Or to word it a little more clearly when you turn key it jumps to around 75 then settles to 60.
Tuesday, August 9th, 2016 AT 1:18 PM
HMAC300
  • EXPERT
Before you replace distributor check to see if rotor moves, it should not if it does the gear is shot on bottom of distributor.
Tuesday, August 9th, 2016 AT 1:21 PM
PATRICK HAUGER
Yes, the rotor pulls up and down a good centimeter.
Tuesday, August 9th, 2016 AT 1:26 PM
WRENCHTECH
  • EXPERT
Your fuel pressure test does not make any sense. The spec is 58 to 64 and it will ever exceed that spec because the regulator bypasses at 64 with the engine off.
Tuesday, August 9th, 2016 AT 1:27 PM
PATRICK HAUGER
It holds steady at 59 60 the jump I would assume is the gauge.
Tuesday, August 9th, 2016 AT 1:29 PM
Recommended Guides
