Security alarm?
TREADWEIGH
  • 1999 HONDA ACCORD
  • 6 CYL
  • FWD
  • 130,000 MILES
When trying to jump start (totally dead) the alarm sounds and lights flash as soon as I connect to a booster battery. It's the factory security system operated now by key only. Is there a way to "reset" this alarm? There has been no change in the key use but the alarm may have been activated and the car immobilized.
I can crank the engine with the alarm blasting but it won't fire because I assume it's in the "immobilized mode".
Sunday, January 23rd, 2011 AT 4:22 PM
KHLOW2008
  • 41,815 POSTS
Is the green key symbol staying on? It must go off to be able to start. If you have a spare key, try using it.
For the horn to be blaring, it is not only the immobilizer. You need to disarm the alarm as well.
this guide will help us fix it
https://www.2carpros.com/articles/how-to-reset-a-security-system
Close all doors and use the key to lock and unlock all doors before opening them.
If that does not wok, you would have to check for blown fuses resulting in no communication between the PCM, security system and key.
Monday, January 24th, 2011 AT 2:46 PM
TREADWEIGH
Thank you! The door/key/lock/unlock cycle reset the immobilizer and it started easily with a jump. I appreciate your help, can I leave a tip?
Monday, January 24th, 2011 AT 8:24 PM
KHLOW2008
  • 41,815 POSTS
You're welcome.
Glad to know you have fixed the problem.
Pleas use 2CarPros anytime we are here to help.
Tuesday, January 25th, 2011 AT 1:29 AM
RICK GIOMBETTI
Thanks for the advice ! Worked well once I reset the alarm by putting the key in the door and reset! Horn stopped honking and light went off! Life saver Thanks ! Jumped right away!
Tuesday, July 11th, 2017 AT 10:22 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,968 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
Tuesday, July 11th, 2017 AT 4:27 PM
JIM DUNHAM
It was said that "Fuse 13 powers the alarm module." Which panel? Driver's side? Passenger? Or engine compartment box?
Thursday, April 5th, 2018 AT 6:18 AM
KEN L
  • 42,968 POSTS
Here are all of the fuse locations and identification as well.
Check out the diagrams (Below)
Cheers, Ken
Thursday, April 5th, 2018 AT 11:19 AM
KEVIN MARQUEZ
  • 1999 HONDA ACCORD
  • V6
  • 120,000 MILES
So I replaced the window regular since the window wouldn’t go up or down so when I replaced it and plug it in it did work but the car won’t turn on at all but lights do show but says like all the doors are open and the trunk and dumb idea to remove the battery and now it won’t stop beeping and keychain doesn’t work. New to this sorry lol I’m assuming it has to do with the door I fixed the regulator since I plugged it in it’s behind the driver seat one.
Saturday, September 26th, 2020 AT 1:24 PM (Merged)
KEN L
  • 42,968 POSTS
Is the security light flashing? It is common to reset the alarm system when the battery has been disconnected. This guide will show how to reset the system:
GOODYSONTHEGREEN
  • 1999 HONDA ACCORD
  • 4 CYL
  • 200,000 MILES
My honda 1999 accords remote is broken and the car alarm is on. How do I disarm alarm.
KHLOW2008
  • 41,815 POSTS
Close all doors and use the key to lock and unlock the door to disarm.
If it fails with one door, try thre other or trunk. If it still does not work, insert key to ignition and turn it on.
NATE4LIFE
  • 1999 HONDA ACCORD
1999 Honda Accord 4 cyl Automatic
hi my name is NATE and I own a 1999 Honda accord, at first when I press the alarm to open the doors on the car the lights would come on and off on the back and the front of the car now its not doing that no more, I dont know whats wrong with it, can u pleace help me?
Saturday, September 26th, 2020 AT 1:25 PM (Merged)
KHLOW2008
  • 41,815 POSTS
Hi nate4life,
If the alarm can be armed and the power locks are working, then try the procedure described in the following link and see if it helps.
NATE2NICE
My car remote does not have the trunk release button, what else can I do?
KHLOW2008
  • 41,815 POSTS
Hi nate2nice,
What problem are you facing?
Are you regiatered with 2 accounts here?
You should ask all related questions in one thread and reply in the same thread so that there wil be a history of the question that you asked and also notification would be received by the person handling your question.
KHLOW2008
  • 41,815 POSTS
Does the locking and unlocking functions work even though the lights ae not blinking?
NATE2NICE
  • 1999 HONDA ACCORD
1999 Honda Accord
hi my name is Nate, and I own a 1999 Honda accord, ever since I buy this car the security alarm would comes on when somebody gentle touch the car or when a bus pass by it. Can u please tell me whats the problem? Thank You
KHLOW2008
  • 41,815 POSTS
Hi Nate,
The vehicle is allergic to touch and vibration ;) just joking.
Most probably you have a door out of adjustment/loose or the door switch is not being activated properly.
Does the door ajar warning indicator light sometime flashes while driving?
If yes, you should check which door is out of adjustment.
With dome light switched to operate with door, sit inside vehicle and close all doors. Push at the door from inside the car and waych out which door turns the dome light on. That is the door that you should check for adjustment or switch problem, could be a missing rubber cover.
__JJ
  • 1999 HONDA ACCORD
  • 4 CYL
  • FWD
  • 98,000 MILES
Took my car to jiffy lube for an oil change today. When I got home, I used the remote to lock the doors and set the factory alarm. The doors locked but the blinkers did not flash and no horn beep indicating the alarm is active. So I tried my wifes remote and same thing. The remotes both lock and unlock the doors but not activate the factory alarm. This function worked by remote only moments before taking my car to jiffy lube. Coincidence? Any help, thanks, JJ
KHLOW2008
  • 41,815 POSTS
Hi JJ,
There is a possibility the audible signal was set to off. Try if the following helps
AUDIBLE SIGNAL
Remote keyless transmitter operation is indicated by the side marker lights, taillights and parking lights flashing once (lock) or twice (unlock). An audible indicator (alarm chirp) can also be programmed. When transmitter battery is replaced, audible indicator will be turned off.
To Switch On Alarm Chirp(s)
1. Using remote transmitter, press and hold trunk release button. Immediately press and hold the lock button.
2. The transmitter LED should light and remain on for one second. After LED goes out, release buttons.
To Switch Off Alarm Chirp(s)
2. The transmitter LED should flash twice. After LED goes out, release buttons.
Remote transmitters may be coded into system.
