Camshaft Position Sensor Location and Replacement?
GSHERRILL
  • 2019 FORD F-150
  • 5.0L
  • V8
  • 4WD
  • 10,000 MILES
Trying to figure out where this sensor is located on the engine.
Thursday, July 9th, 2020 AT 4:43 PM
I attached the location of the CMP21 sensor. As you can see it is on the back of the head on the driver side. I also attached the info on the code I assume you have.
However, I should say that if you are having an issue, it would be wise to take this to a dealer because unless the issue is as a result of something you altered on the truck, it will be covered under warranty. If the finds that you have been working on the truck, they may give you a hard time and say you caused the issue so it is always best to have them look at it and repair the issue.
Thanks for using 2CarPros.
Thursday, July 9th, 2020 AT 5:10 PM
GSHERRILL
Thank you for the info. I understand about the warranty. We are set to go on vacation on Monday and no dealer can get it in before then and they don't have any loaner vehicles available.
Thursday, July 9th, 2020 AT 5:51 PM
Totally understand. Please let us know if you need more info. It may be worth calling some further dealers or talking to the service manager but with it being towards the end of the week, it would be a tight time frame. You could also try calling the Ford customer service just to see if they would be willing to pay for a rental while your vehicle is being worked on and you go on vacation. Just to be clear, a loaner car is a dealer owned vehicle that they "loan" out while the vehicle in for service. A rental car is from a company like enterprise and the dealer pays for it and then gets reimbursed on the warranty claim when they submit that.
I used to work for Ford and now work for another OEM and they do that all the time.
Thursday, July 9th, 2020 AT 7:30 PM
GSHERRILL
Thanks again for the diagram. It was a 5 minute job and it appears to have fixed the issue. No more check engine light and the truck has full power again. FYI, the code it gave was P0345 incase anyone is wondering.
Friday, July 10th, 2020 AT 2:51 PM
That is great info. Thanks for the update and glad you are all set for your vacation. I figured that was the code you were getting. Thanks for using 2CarPros. Come back if you need help in the future. Thanks
Friday, July 10th, 2020 AT 8:39 PM
TREVOR JARAMILLO
  • 2016 FORD F-150
  • 2.7L
  • TURBO
  • 4WD
  • 35,000 MILES
Truck listed above has the ecoboost engine. I have been looking all over and can't find any information close to my truck year and engine. If you have pictures or videos it would be helpful. Thank you.
Friday, August 21st, 2020 AT 2:49 PM (Merged)
  • 108,336 POSTS
There are a total of 4 cam sensors on this engine. I have attached two pics below showing locations. Take a look and let me know if that helps. Also, if you know what sensor needs replaced, I will be happy to provide the directions / pics for doing it. If you provide the code set, I can get it from that.
METALJONES
  • 5 POSTS
  • 2016 FORD F-150
  • 5.0L
  • V8
  • 4WD
  • 54,000 MILES
I need to replace the camshaft position sensor (intake). I’m having trouble locating it.
Friday, August 21st, 2020 AT 2:50 PM (Merged)
SCGRANTURISMO
  • 4,897 POSTS
They are located on the rear of the cylinder head. There are two per cylinder bank, one intake, one exhaust, for a total of four sensors. I have included a factory description in the diagrams down below. Let us know if there is something else we can help you with.
Thanks,
Alex
2CarPros
METALJONES
  • 5 POSTS
Thank you for the information.
I’m not sure the diagram is correct.
  • 108,336 POSTS
Welcome to 2CarPros.
The sensors are on the rear of the engine. There are two per side, one for the intake cam and the other for the exhaust. I have attached a picture to help you locate them. The first picture shows location. The second picture is a legend of the components listed. You are looking for numbers 1 and 7 on the legend.
Here are the directions for removal and replacement. Pictures 3 and 4 correlate with these directions.
NOTE: Removal steps in this procedure may contain installation details.
RH (right-hand) Camshaft Position (CMP) Sensors
Remove the RH fender splash shield.
Refer to: Fender Splash Shield (501-02 Front End Body Panels, Removal and Installation).
Disconnect the intake CMP sensor electrical connector and remove the retainer and the CMP sensor.
Material : Motorcraft SAE 5W-20 Premium Synthetic Blend Motor Oil / XO-5W20-QSP (WSS-M2C945-A)
Torque : 89 lb. In (10 Nm)
Disconnect the exhaust CMP sensor electrical connector and remove the retainer and the CMP sensor.
Picture 3
LH (left-hand) Camshaft Position (CMP) Sensors
Remove the LH fender splash shield.
Position aside the radio ignition interference capacitor.
Picture 4
Installation
NOTE: Before installation, lubricate the CMP sensor O-ring seal with clean engine oil.
To install, reverse the removal procedure.
METALJONES
  • 5 POSTS
  • 108,336 POSTS
You are very welcome. Let me know if you need anything.
METALJONES
  • 5 POSTS
One more question.
Which are the intake sensors?
ECO2015
  • 8 POSTS
  • 2015 FORD F-150
  • 2.7L
  • TURBO
  • 4WD
  • 63,000 MILES
So it seems that everyone who has an issue with the Camshaft sensor can't find them. Well I believe I have found them, but would really like to make sure.
So, the check engine light would come on and off, but I never noticed any running issues. It came on and I and I had it scanned. The scan was P0365.
Two days later my truck started running rough and I couldn't go over 40-50 miles a hour. It take a long time with the key turned over to start.
P0365 Camshaft Position Sensor B Circuit Bank 1
I believe that there are two Camshaft sensors on the passenger side at the rear of the engine. 1 is more towards the direct rear and the other off to the rear passenger side.
I did replace the one at the rear and still had the issue. I put the old sensor back in and put the new one in the one off to the passenger side rear and still had the same issue.
I would appreciate some help on this. This website and you guys are invaluable.
Thanks.
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
What do you mean by intake sensor?
Thanks,
Alex
2CarPros
  • 108,336 POSTS
Bank 1 will be the passenger of the vehicle. I attached a picture below and circled sensor B. Is this the one you are referring to?
METALJONES
  • 5 POSTS
There are four CMP sensors, two intake and two exhaust.
ECO2015
  • 8 POSTS
Yes, that's the one. That is honestly the best diagram that I've seen. I ended up changing the one your circled and still had the problem. So, I put the old sensor back in and changed out the other one. I was trying to rule out which sensor had the issue since I didn't know which one was sensor B.
Tomorrow I will change it back out to the right sensor. My problem is that even when I changed sensor B, it did not change the way the truck ran. I unhooked the battery before changing them out.
My plan going forward is to change out both sensor and see if that fixes the issue. I have been reading about the wire harness potentially being bad.
I appreciate you taking the time to help me navigate this.
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Yes there are. Joe should have sent some outstanding diagrams and location descriptions in his first reply. I would refer you to those, please.
Thanks,
Alex
2CarPros
