1999 Cadillac Deville Service Steering System/Traction Cont
DJMILES04
  • 1999 CADILLAC DEVILLE
Steering problem
1999 Cadillac Deville Engine Size unknown Wheel Drive Type unknown Automatic 122000 miles
Just the other day my cadillac started showing service steering system and traction control came on. Im very worried about this problem. Also it says service stability system. Please help me
Do you
have the same problem?
Thursday, February 21st, 2008 AT 2:56 PM
MASTERTECHTIM
You need to have the computer scanned and tell us the code. Dont be worried your car will always still have conventional brakes. When the light comes on it disables that module completely so it wont do anything funky while your driving it.
Thursday, February 21st, 2008 AT 3:44 PM
DJMILES04
Current:
TCS C1287 Steering Sensor Rate Malfunction
TCS C1241 Magna Steer Circuit Malfunction
PCM P0151 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 1
MMM B2144 Left Front Mirror Vertical Position Sensor Circuit Low
MMM B2146 Left Front Mirror Horizontal Position Sensor Circuit Low
MMM B2148 Right Front Mirror Vertical Position Sensor Circuit Low
MMM B2150 Right Front Mirror Horizontal Position Sensor Circuit Low
History:
IPC B1911 Generator L-Terminal Problem
TCS C1277 Requested Torque Signal CKT Malfunction
TCS C1281 Steering Sensor Uncorrelated Malfunction
TCS C1286 Steering Sensor Bias Malfunction
Thursday, February 21st, 2008 AT 8:39 PM
MASTERTECHTIM
See pm
Friday, February 22nd, 2008 AT 6:10 AM
BUZZSAW
Current:
History:
TCS C1286 Steering Sensor Bias Malfunction[/quote:3f6e813176]
looks like you need a steering wheel position sensor first, an O2 sensor, the one on the frt head, its under the water pump, ck your brake fluid, fill it if its low, start there
Friday, February 22nd, 2008 AT 2:11 PM
Recommended Guides
