My blower motor is not working
PORKCHOP #1
  • 2008 KIA SPORTAGE
  • 6 CYL
  • 4WD
2008 Kia Sportage blower motor stopped working. Where is location of Resistor under dash?
Sunday, July 17th, 2011 AT 11:38 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,959 POSTS
There is a blower motor relay and fuse and the blower motor itself. Here is a guide on how to check and replace the blower motor. The MOSFET is the resistor
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
It is not on your car but you get the idea. It could be fuse as well, here is a guide for that as well.
Here are the blower motor and air conditioner wiring diagrams and fuse panel locations as well as the resistor location. Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Tuesday, November 14th, 2017 AT 1:07 PM
N16NITRO
  • 2008 KIA SPORTAGE
  • 48,000 MILES
My a/c and heating unit have been having problems and now my kia is not having cold air coming out. Its always blowing hot air but when I turn the car engine off and turn the air on the a/c side blows cool air not cold air. What could be the poblem of this? I did just have trouble with my blower not working and I got that to work. Could that could have cause somthing?
Friday, June 19th, 2020 AT 11:18 AM (Merged)
KHLOW2008
  • 41,815 POSTS
Did you check the A/C freon pressure and does compressor clutch engages when A/C is turned on?
N16NITRO
I have alot more info now on whats its doing so I hope u can answer my question. Its alaways blowing hot air out and its only coming out of the 2side ones and my front defrost vent. It only starts vlowing hot air when the car gets up to temp too. The compressor does engage too.
NANCYULAKOVIC
  • 2005 KIA SPORTAGE
  • 4 CYL
  • 195,000 MILES
My air/heat blower motor
isn't working in my kia sportage 2005
KHLOW2008
  • 41,815 POSTS
Try banging the blower otor housing and if the blower starts working, the fan motor is failing and requires replacement.
Have you check the fuses?
DONGIBSON
  • 12 POSTS
  • 2006 KIA SPORTAGE
  • 4 CYL
  • 130,000 MILES
Removed blower motor and it tested good. Checked the following and found no power at blower motor or resister. Pulled dash and there is power at the fan switch.
Fuses checked and are good. Concerning the relays, I was not 100% sure which one, if any to check so I just switched them around with others of the same value. Did not seem to effect anything.
Where do I go from here? Any other fuses or relays to check? Does the fact that there is power at the switch and not at the resistor suggest it is the fan control/switch that is the problem or a short between switch and resistor? I am assuming that power goes from switch right to the resistor or maybe not?
Thanks
AL514
  • 4,120 POSTS
The blower motor is controlled by the HVAC control unit grounding the motor, you should have power on the red/white wire coming to the blower motor with the ignition switch in the on/run position all the time. Considering you say there is no power there, the two fuses to check are on this wiring diagram. First one is the air conditioner 10 amp fuse in the panel under the dash on the left end, the other fuse is the Blower Fusible Link 40 amp located in the E/R Junction block in the left front corner of the engine compartment, both of these fuses send power to the blower relay. You can see all this in the diagram. Once you get power to the blower motor you can ground the other side of it (yellow wire at the blower motor plug to make sure the motor itself runs).
I believe the resistor in this case only limits the current flow on the ground circuit, not voltage. But has the same effect, slowing or speeding up the fan motor. But the power on that Red/White wire is the concern at this point.
But also if one of these two fuse's is blown, you are going to want to figure out why it popped to begin with.
DONGIBSON
  • 12 POSTS
Thanks for the responses. I ran a wire from the battery to the blower in order to get heat until I figure out the problem. I checked the 40 amp in the engine compartment as well as the AC fuse and both are working. Do I have a short?
AL514
  • 4,120 POSTS
So you have no power going to the blower on the Red/White wire at the blower motor? Did you have to run a ground wire to the blower motor also or did you just run power to it and used the controls inside the car?
DONGIBSON
  • 12 POSTS
Correct, no power at the connection. I ran my own wire from battery to the blower and grounded the other pin. The blower works. The fan control does not.
DONGIBSON
  • 12 POSTS
Could it be the resister?
DAWN SMITH2
  • 2006 KIA SPORTAGE
  • 2.0L
  • 4 CYL
  • 4WD
  • MANUAL
  • 110,000 MILES
Trying to replace the blower motor, the connector does not come off. Is it hard-wired, rather than plug and play?
Thanks for any help!
CJ MEDEVAC
  • 11,004 POSTS
Look at two pf the pictures at this site
http://www.rockauto.com/en/catalog/kia,2006,sportage,2.0l+l4,1432789,heat+&+air+conditioning,blower+motor,6916?a=Referer+www.google.com+URL+%2F
One brand shows it plugging into a connector (on two wires)
The other brand shows it plugging into the body of the motor.
It does plug in, in either scenario.
Return with good news!
The Medic
AL514
  • 4,120 POSTS
Well the control unit uses the ground side of the blower motor to control it, so you may want to run power to it but keep the harness plugged into it, this will rule out the control unit, and it will just be a power supply that you have to deal with. The resistor is on the ground side of the circuit according to the wiring diagram. As you can see in this diagram if you have no power at that harness plug for the motor with the key on, then that's the issue, it should be coming straight from the relay. Try what I mentioned above, keep it plugged in and run power to that Red/White wire by back probing the connector and see if it will come on. The relay may have a bad ground or the power wire coming in could be open somewhere.
Is this Red/White wire running to the resistor?
It should only go straight to the relay according to the book, I am hoping this wiring diagram is not wrong.
It seems if you have no power on that wire, that's the issue and the control unit should be okay. Running power to it from the battery was a good way to check it.
CJ MEDEVAC
  • 11,004 POSTS
Looks like you are going to have to copy and paste the whole link or look through the catalog like I did.
The Medic
DONGIBSON
  • 12 POSTS
I am not sure if the red/white wire runs to the resistor. I will check and update. I was thinking that the power goes through the resister and on to the blower, but I guess I was wrong about that. Can you explain what you mean by back probe the connector? I am confused by that term.
DONGIBSON
  • 12 POSTS
Oh, and when you say the power goes from the relay to the blower. What relay are you referring to? The 40 amp fuse?
DONGIBSON
  • 12 POSTS
40 amp under the hood?
DONGIBSON
  • 12 POSTS
I will update you tomorrow. It is too dark to see what I am doing. Thank you very much!
