Anti-theft
JIMEL48
  • 2001 FORD RANGER
  • 6 CYL
  • 120,000 MILES
I was recording data with a Actron code reader and while it was recording I replaced a coil wire. When I tried to erase a 305 code the code reader quit picking up a signal. When I tried to start the truck I did not have any power to the truck except for the theft light on the dash flashing. I do get a clicking around the middle of the dash when the key is in the cylinder and open the door. Clicking goes off when I tun the Key. Any ideas?
Sunday, August 14th, 2016 AT 2:35 PM
WRENCHTECH
  • 20,758 POSTS
Try locking and unlocking the truck from outside and check all your fuses with a test light. It sounds like you tripped a theft deterrent.
Sunday, August 14th, 2016 AT 3:23 PM
JIMEL48
  • 28 POSTS
Thanks, I am going to try a different pcm relay.
Sunday, August 14th, 2016 AT 7:35 PM
QUICKERR
  • 2000 FORD RANGER
  • 3.0L
  • V6
  • RWD
  • 155,000 MILES
Truck was turning over but not firing or getting fuel. Assumed it was anti theft. Tried a reset trick, now it will not crank. Also, anti theft light is blinking fast. Let me add. The anti theft light was flashing fast before trying anything. I do not have a second key. The "trick" was door open, ignition on, disconnect and reconnect the battery. Something I saw online. So, that is the only option? Is it possible that certain shops may have the scan tool? Or dealer only?
Monday, June 1st, 2020 AT 1:21 PM (Merged)
WRENCHTECH
  • 20,758 POSTS
I would try a hard system reboot this is done by removing the negative battery cable from the battery and holding it to the positive battery terminal for 1 minute this will discharge the system capacitors.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Let me know how it goes.
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,072 POSTS
Hey QUICKERR,
I would look at all if the fuses and test the starter relay, here are a couple guides and a diagram to hep you do some testing and get the problem fixed.
and
Please run some tests and get back to us so we can continue helping you.
Monday, June 1st, 2020 AT 1:22 PM (Merged)
CSMOHT
The system hard reboot worked for me btw.
DALTON VARNES
Hi I have a 99 ranger and I lost the key and my dad tried to make my none chipped key work and he set the anti theft on so I don't get fuel or spark and I have tried rebooting by undoing the negative and touching the positive multiple times and all my fuses are good so what can I do? I bought this truck before my birthday last year put a motor in it and only got to drive it like 10 times and no one said they can help me
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
If you have a (vpats) chipped key you will have to replace with another chipped key.Non chipped keys will not work.Here is a tutorial showing how to reset the anti-theft/security system but it's probably going to be a long shot by having your non chipped key:
After reading scroll down the page to find Ford. Hope this helps and thanks for using 2CarPros.
Danny-
DEC17JJ
  • 1998 FORD RANGER
  • 6 CYL
  • 51,000 MILES
I have had this truck for 4 yrs and didn't even know it had an anti theft system. I changed the battery and now the alarm goes off and it won't start. I disabled the horn I have power but no start
DAVE H
  • 13,383 POSTS
Try resetting it here is a guide
STALLIONPLAYBOY
  • 1998 FORD RANGER
Computer problem
1998 Ford Ranger 6 cyl Two Wheel Drive Automatic
I'm wanting to know if it is possible to add a car alarming system with remote start and auto door locks if my 98 ranger has neither a previous alarm nor auto doorlocks?
SERVICE WRITER
  • 9,123 POSTS
There are aftermarket accessories available that can be added for this. It is somewhat of a specialty service that not all shops get involved with. But a few phone calls should be able to narrow it down
