Air in left front caliper every couple weeks.
RMITTNER
  • 1999 FORD EXPEDITION
  • 4.6L
  • V8
I have to bleed the left front caliper about every 3 weeks. Changed Master, Break lines, and hose. Peddle is good after bleeding, but only lasts a month at the most.
Do you
have the same problem?
Thursday, August 28th, 2014 AT 10:42 AM
HMAC300
  • EXPERT
You have air in the abs unit, have a pro use his scanner to open the valves and bleed it
Thursday, August 28th, 2014 AT 10:50 AM
RMITTNER
Thank you!
I have already done that, but it seems that the abs is creating air. Have you ever heard of this?
Friday, August 29th, 2014 AT 5:56 AM
HMAC300
  • EXPERT
T can take up to 3 qts to bleed a system now adays it may be the boost valve inside th abs causing the problem. I guess it could cause it but I've never realy heard of it.
Friday, August 29th, 2014 AT 6:35 AM
RMITTNER
Thanks again!
I will give it a shot!
Friday, August 29th, 2014 AT 8:17 AM
Recommended Guides
