How to remove power steering belt?
WANGZHE18
  • 1996 TOYOTA COROLLA
Steering problem 4 cyl Front Wheel Drive Automatic 89375 miles
I am trying to loosen power steering reservior in order to remove old belt for replacement. But there are one belt on the top and three belts at the bottom. Which two are pivot and lock bolts that I have to loosen please? Any help highly appreciated! Thank you.
Tuesday, April 14th, 2009 AT 5:45 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Here is a guide that will show you what you are in for when doing the job
https://www.2carpros.com/diagrams/toyota/corolla/1996
This can help as well.
https://www.2carpros.com/articles/replace-serpentine-belt
Cheers, Ken
Tuesday, April 14th, 2009 AT 10:37 PM
MMPRINCE4000
  • 8,548 POSTS
You have to loosen pivot bolt and the PS mounting bolt at base of PS unit, it can be hard to get to, remove RF tire and stone guard for better view.
Wednesday, April 15th, 2009 AT 6:25 AM
WANGZHE18
Thanks for your help! It's 1.6L, and your uploaded picture is a view of the generator. What I have no clue is the pivot and mounting/lock bolts for the power steering pump. There are about 4 or 5 bolts on the back of the P/S pump, and I don't know which ones to loosen. Any more help highly appreciated!
Wednesday, April 15th, 2009 AT 7:11 AM
WANGZHE18
Thanks for the help, mmprince! Which one are the pivot the PS mountin bolt please? There are several back there, and I don't know how to identify. Million thanks!
Wednesday, April 15th, 2009 AT 7:14 AM
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_1_47.jpg
Tension on the power steering belt is adjusted by means of an idler pulley (some models may use just a lower adjusting bracket setup-similar to alternator adjustment service procedure). Loosen the lock bolt and turn the adjusting bolt on the idler pulley until the desired tension is felt and then tighten the lock bolt.
Wednesday, April 15th, 2009 AT 10:30 AM
WANGZHE18
Thank you all for your answers and help! Really appreciated!
Wednesday, April 15th, 2009 AT 3:52 PM
DAVIDTHEBMXER
  • 19 POSTS
  • 1.8L
  • 4 CYL
  • FWD
  • 96,000 MILES
When I start the car there is a squeel then when I put it into gear it turns into a louder higher pitched chirp. I just changed the alternator beltt and the belt is tight. The squeel stops once the car is warmed up.
Saturday, February 17th, 2018 AT 1:37 PM (Merged)
HMAC300
  • 48,601 POSTS
If you replaced the belt you should have replaced the tensioner spray water on belt and if noise goes away replace tensioner
DAVIDTHEBMXER
  • 19 POSTS
The alternator is used to tighten the tension, this car doesnt have regular tensioners.
HMAC300
  • 48,601 POSTS
Then put a belt tension gauge on the belt and see if it's tight enough.
2CP-ARCHIVES
  • 4,540 POSTS
How to change a 1.8 liter engine power steering belt?
Or how to tighten?
KHLOW2008
  • 41,814 POSTS
Loosen the pump bolt and pull at belt to get the belt to slacken for removal.
Reverse procedure for installation and retighten pump bolt after getting correctbelt tension.
PATRICK FRY
  • 1994 TOYOTA COROLLA
Steering problem
1994 Toyota Corolla 4 cyl Front Wheel Drive 180000 miles
Is it feasable to replace a broken power steering belt on my car if I am somewhat mechanically inclined? I have worked on my Ford truck so I am better with American cars. Or should I just head to a service station? Is this a job that can be done in my driveway?
  • 31,937 POSTS
Hi there,
It is possible to replace it in the drive way, you will have to jack it up and remove the wheel, as this will make the access to the pump bolts easier, have a go you should be ok with this.
Mark (mhpautos)
HENRY BAGASAN
I want to replace the steering belt because of squeaking sound & found out that it is already sliding when I turned the wheel to the fullest right & left, do you have a video of how to replace it?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 55,211 POSTS
Hey HENRY
That is not to bad of a job, here is a diagram that will show you what you are in for.
https://www.2carpros.com/diagrams/toyota/corolla/1994
Please let us know happens so it will help others.
Best, Ken
DEEPBLUESEA1226
  • 7 POSTS
  • 1998 TOYOTA COROLLA
  • 4 CYL
  • 90,000 MILES
Engine Mechanical problem
1998 Toyota Corolla 4 cyl Two Wheel Drive Automatic 90000 miles
I want to know what is the easiest way to change the belt with air condition unit by myself. Please show me the way to change it.
Thankyou very much
MMPRINCE4000
  • 8,548 POSTS
Move tensioner pulley (arrow in picture) to release tension on belt, then remove belt.
Buy a good belt, Dayco, Gates, Goodyear, Toyota. Use brake clean to remove any contamination from pulleys, make sure pulleys are tracking properly.
https://www.2carpros.com/forum/automotive_pictures/108325_belt_routing_corolla_2.jpg
DEEPBLUESEA1226
  • 7 POSTS
I found the tensioner pulley, but I couldn't push it down like the photo shown. Do I need some tool too release the tension?
Saturday, February 17th, 2018 AT 1:38 PM (Merged)
MMPRINCE4000
  • 8,548 POSTS
A tensioner tool is available from most autoparts stores for rental.
Try a socket on a long ratchet.
