1996 Nissan Sentra Will not start
MIGHTYPELAY
  • 1996 NISSAN SENTRA
  • 4 CYL
  • FWD
  • 141,000 MILES
My car got entirely flooded and now it will not start. What are the problems I can check for to get it to start?
Monday, October 13th, 2008 AT 5:26 AM
Do below to determine if its fuel or spark issue
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Monday, October 13th, 2008 AT 5:30 AM
CHARLESIMMAK
Wh0cd609528 cytotec buy clindamycin Buy Elimite
Monday, May 29th, 2017 AT 8:51 PM
HMAC300
  • 48,601 POSTS
If your car got flooded then scrap it and get another one all the electronic modules in the car have been destroyed.
Tuesday, May 30th, 2017 AT 6:02 AM
