I have tracked a non starting issue to the fuel pump or fuel pump relay. I cannot however locate the relay in question.
Apr 19, 2017 at 6:51 PM
STEVE W.
CAR REPAIR CONTRIBUTOR
It uses a fuel pump control module tucked up by the fuel tank. It does not turn the pump on/off like a relay. Instead it controls fuel pressure by rapidly pulsing the power to the pump in response to the ECMs commands. The ECM uses the sensors and fuel pressure sensor to determine the pressure needed. To test them you need a good scan tool to command the pump to certain pressures as you run the tests. You will also need to program the replacement module (if it tests faulty) so it matches the engine/vehicle.
Here is a guide to help you test the relay with diagrams below to show you the location
Images (Click to enlarge)
Apr 19, 2017 at 7:45 PM
AUXIERGINGER
MEMBER
i cannot locate the fuel pump relay.
Aug 27, 2020 at 12:28 PM
(Merged)
CARADIODOC
On "upper relay carrier on vehicle electrical system control module".
This is listed as "attached to the instrument panel central tube, and can not be removed without removing the instrument panel. The individual relay sockets can be removed without having to remove the relay panel".
Sorry that I cannot find a picture, and that the engineers found such an effective way to make troubleshooting a miserable experience. I knew there was a reason I do not work on VW's.
(Merged)
DEE GREEN
MEMBER
Okay, now my fuel pump went out. I did all the steps as far as replacing the relay then the fuel pump start it up and ran for a day went to the store shut the car off now it will not start. What do I do now?
(Merged)
AL514
Hello, thanks for using 2CarPros.com. You are going to want to do a fuel pressure test to see what is really going on with that pump. If you have no fuel pressure, you are going to have to do some electrical testing to see if it is the relay or the pump itself.
I have a Bad fuel pump or relay, how do I easily check? I want to check relay, but don't know where it is. Where is relay on this car?
(Merged)
EXOVCDS
Happy New Year!
Have a look at the attached image... pull the relay and look at the circuit
diagram on the side of it. You will want to bridge slot 30 and 87 in the
relay socket to activate the pump.
Thomas
Image (Click to enlarge)
(Merged)
BAGSTER
MEMBER
i have a wagon 2002 month 6 I turn the key to start it and the shift light wont stay on and the car will not start. It turns over fine. the fuel pump does not turn on no whining or noise.
I checked the fuel pump and is works when i apply current to it. I have been unable to locate the relay and the dealer is unable to supply a relay that matches any i have under the dash.
I have another car exactly like it only a 2003 when i turn the key on the shift light goes on and stays on. This is the foot llight on the shift console next to the handle. I turn the key on the 2002 and it blinks on then off i also hear a click from the relay inside the console. what is causing this?
(Merged)
DOCFIXIT
Hi
Fuel pump relay in panel under left side dash see diagram
See no relay in console is there a part number
Shift light off trans in emergency running with a malfunctioning control module.
Hope this helps
Thanks for donate
(Merged)
BAGSTER
MEMBER
That is not the panel in my car
The fule pump relay is close but not the same
Part no 1J0 906 383B does not fiit there are 2 less connectors on mine and the power feeds are smaller connectors.
There is nothing in bank 4 on my car
The missing relay is pictured
Where is the malfuntioning control module located for the transmission light?
(Merged)
SILVIASLIDER
MEMBER
1 POST
Engine Mechanical problem
1995 Volkswagen Passat 6 cyl Front Wheel Drive Automatic
my passat wasnt getting fuel, so i replaced the fuel pump. it did fix it, the pump wont pump at all. i was wondering if maybe there is a relay switch or somthing. if not what could the problem be.
(Merged)
Inspect and test the fuel pump relay and fuse no. 18 20amp
(Merged)
