Mechanics
REPLACE CV BOOT OR AXEL
1995 Toyota Camry
Drive Train Axles Bearings problem
1995 Toyota Camry 6 cyl Front Wheel Drive Automatic 73,000 miles
What is the estimated time and cost to replace a CV boot or an axel on a 1995 Toyoda Camry Station Wagon? Thanks
AD
M2009
September 29, 2009.
The alxe needs removed regardless if it is getting replaced or just the boot. Aprox 1.5 hours. Plus, add another.5 hours if you replace the boot only because the joint must come off.
The half shaft (axle) will be aprox 200.00.
AD
