Mechanics
CRANKS BUT NO SPARK FROM DISTRIBTOR
1994 Toyota Camry
Electrical problem
1994 Toyota Camry 4 cyl Two Wheel Drive Automatic 210692 miles
No spark, has new coil, and igniter, Just quit running.
Has fuel pressure, all fuses are good.
Rotor is turning when engine is cranked over.
I dont know what to do.
AD
Kbaja_2000
June 3, 2010.
Inspect and test the distributor pick-up coils resistances and short to ground. Check the fuel pressure if its within specs and also if the injectors are pulsing.
Rasmataz
Jun 3, 2010.
AD
