Front windshield wipers not working
BEOPNL
  • 2005 VOLVO XC90
  • 2.5L
  • 5 CYL
  • TURBO
  • AWD
  • 84,000 MILES
I recently bought this car and the front wind shield wipers are not working at all, but the rear wiper and windshield spray are working. I tried to change the relays and fuses also replaced the front wiper motor and still nothing. Please let me know what could it be. The windshield wipers suddenly stop working from time to time. They will be operating perfectly, then they will just stop. When I turn the engine off, remove the keys, then restart the car, they seem to work fine again. Any suggestions as to a cause/cure for this? This model has the "auto" feature on the wipers, but the wipers shut off in any mode, with the auto feature turned on or off.
Saturday, February 15th, 2014 AT 5:05 PM
HMAC300
  • 48,601 POSTS
There are three fuses and two relays that run the system. You must be losing power or the wiper motor is out let's find out which. Please check out these guide and then come back to check out the diagrams below. Also test through the CEM as well here is a wiring diagram to show you how the system works.
and
and
Here are the diagrams for the windshield wiring and fuses
Check out the diagrams (Below) See where you are losing power
Cheers
Sunday, February 16th, 2014 AT 8:00 AM
JIS001
  • 3,408 POSTS
You may want to start with a central electronic mudule software update to see if these will correct the problem. These can be done at a dealership or any shop that has that capability of downloading software.
Friday, January 20th, 2017 AT 4:00 PM (Merged)
JULIANCELLO
  • 2005 VOLVO XC90
  • 2.5L
  • V6
  • MANUAL
  • 95 MILES
The front wind shield wipers are not working at all, but the rear wiper and windshield spray are working. I tried to change the relays and fuses. Also, replace the front wiper motor and still nothing. Please let me know what could it be.
JOHNNYT73
  • 924 POSTS
It sounds like you have a wiper motor that is out, Can you use this guide to check for power?
Use the diagrams above please
JULIANCELLO
Thank You for answering I really appreciate it. I already did changed the switch, but still nothing. So I check for power at that motor and it is getting power. But not moving is the motor bad?
JOHNNYT73
  • 924 POSTS
It sure sound like it here are some diagrams (below) to help you get it changed out.
Cheers
JULIANCELLO
Thank you again! That worked installed a new motor and bam! Its working thanks 2Carpros
JOHNNYT73
  • 924 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Cheers
JULIANCELLO
I will :)
SAMIT NAIK
Hi, I have this problem never ending. The motor is fine checked and also changed the motor switch which is a simple switch, changed the stalk for wiper, checked the relays and fuses all okay. The scanner says high voltage to motor and low voltage to rain sensor. What can this be?
Tuesday, August 21st, 2018 AT 8:49 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,895 POSTS
This sounds like you have an upper electronic module has gone out. What happens is it is up by the mirror and it gets super heated on how summer days takes it out. Check out the wiring diagrams in the above posts so you can see how the system works. You will need to have the module initiated. Here are instructions for the replacement below.
Check out the diagrams (below). Please let us know what you find.
Cheers, Ken
Thursday, August 23rd, 2018 AT 11:11 AM
