Mechanics
FUEL PUMP
2001 Saturn SC2
Engine Performance problem
2001 Saturn SC2 4 cyl Front Wheel Drive Manual 98000 miles
how do I change the fuel pump
Mike halacy
June 12, 2010.
If the fuel pump is inoperative, the tank can be drained by siphoning from the tank. A suitable means is through the fuel filler pipe with the "correct" type and stiffness of tubing as used with the Fuel Tank Drain Hose SA9804E.
CAUTION: DO NOT ATTEMPT TO INSERT ANY OTHER TYPE OF SIPHON HOSE OR TUBE INTO THE FUEL FILLER PIPE. THE DESIGN OF THE INLET CHECK VALVE AT THE END OF THE FUEL FILLER TUBE (SEE "FUEL INLET CHECK VALVE") RESTRICTS THE INSERTION OF A HOSE AND, MOST IMPORTANTLY, PREVENTS THE REMOVAL OF THIS HOSE. IF THE SIPHON HOSE BECOMES STUCK IN THE CHECK VALVE, THE FUEL FILLER PIPE WILL NOT BE ABLE TO BE REMOVED FROM THE FUEL TANK WITHOUT DAMAGE TO THE FILL PIPE OR FUEL TANK.
http://www.2carpros.com/forum/automotive_pictures/12900_f1_1.gif
Disconnect the negative battery cable.
Open fuel filler door and remove gas cap.
Insert fuel tank drain hose guide/funnel into fuel filler pipe.
http://www.2carpros.com/forum/automotive_pictures/12900_f2_1.gif
Insert fuel tank drain hose (SA9804E) into guide funnel and into fuel filler pipe. Some resistance may be encountered when the tip of the siphon hose reaches the inlet check valve. Repeated probing may be necessary to slide the hose tip through the check valve cage. IMPORTANT: The fuel tank drain hose will reach the bottom of the tank within about 25 cm (10 in.) of the end fitting (and tag). When connecting the fuel tank drain hose to another length of hose connected to the fuel drain tanker: DO NOT insert the fuel tank drain hose into the fill pipe funnel past the tag at the fitting end. If inserted too far, the upper portion of the fuel tank drain hose may pass through the check valve cage and then jam on attempted removal.
Begin the fuel siphoning process. NOTE: The fuel flow rate from the fuel tank drain hose will range from 1.1 l/mm (0.3 gal/min) up to 3.8 l/mm (1.0 gal/min) (depending on whether it is gravity siphoned or siphoned with an air-powered pump).
Remove fuel tank drain hose from fuel filler pipe after draining is complete.
Rasmataz
Jun 12, 2010.
AD
