2004 Saturn Ion Repair Question
Asked on July 17, 2010
Power steering
Steering problem
2004 Saturn Ion 4 cyl Two Wheel Drive Automatic
I attempted to jump a car and during the process i saw PWR STR appear on the dash and when i left the area I noticed I had NO power steering. How can I troubleshoot this issue? Would it be as simple as a fuse or would i need to get a whole new pump? Suggestions?
Answer
Replied on July 18, 2010
First of all thank you so much for your donation.Most likely you just blew a fuse it's going to be in you under hood fuse box there's two of them for it.There labeled EPS number 42 and 43 there 30 amp there going to be the outer square fuse's.They have a clear window on the top so you can see which one's are blown.
