Engine wont run?
MKRINER1102
  • 1993 PLYMOUTH ACCLAIM
  • 4 CYL
  • FWD
  • 203,000 MILES
Started car on a work day drove appx. 14 miles one way got to work shut car off for about 15 mins came out car would not start let set for 5 hrs car started then drove home no problems. Went to leave home car would not start. Checked the alternator, starter, distrubitor everything is working has power to turn motor but will not start looking for fuel filter but cant find. I am now grasping at straws can you help?
Monday, December 22nd, 2008 AT 8:41 PM
  • 108,289 POSTS
Hi:
Are you getting spark and fuel to the engine? The fuel filter is near the fuel tank.
Let me know what you find.
Friday, March 20th, 2009 AT 9:54 PM
MACKALLMIKE
Engine Mechanical problem
1993 Plymouth Acclaim 6 cyl Front Wheel Drive Automatic
I have a 93 plymouth acclaim and 1 day as I was driving it just cut out while I was driving and when I tried to start it back up it would crank but will not turn over what could it be
Friday, July 24th, 2020 AT 6:18 PM (Merged)
  • 31,937 POSTS
Hi there, you will have to get a code check done , and see if you have spark, fuel pressure and injection pulse, also check this link as it should be of help to you.
https://www.2carpros.com/first_things/car_cranks_but_wont_start.htm
Mark (mhpautos)
DHANSEN
  • PLYMOUTH ACCLAIM
My 1992 plymouth acclaim (110,000 miles 4 cylinder automatic) died on me while I was driving and won't start. It cranks but won't start.
In the past it's made loud screaming noises when I started the car and a chirping noise when I drive it.
What do you think it could be?
Friday, July 24th, 2020 AT 6:19 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
There is a list of what it could be. When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
GNOMURA
  • PLYMOUTH ACCLAIM
We have a 1992 Plymouth Acclaim. The car just will not start or turn over. I checked all the fuses, the battery is still good, and when you turn the key to the on position it does nothing. Everything else works. Radio, wipers, turn signals, stop lights, flashers, and all. Do you think it is the starter? My son just put in a amp for his stereo. Will that have to do anything with the car not starting?
JDMHATCH91
  • 13 POSTS
Do you herar a click click whe you turn key to crank? If you dont hear that click click, its probrobly your starter
THEMEANBRADFORD
I had the same exact problem with a 98 plymouth Breeze. If it is the same way. Lock the doors with the keyless entry remote, then unlock it. That should work. It has something to do with the alarm system.
JDMHATCH91
  • 13 POSTS
Ok first of all your car is a van, and 4 years younger. Any plymouth acclaims 89-95 did not come with the option of keyless entry so that probrobly wouldnt be the problem. Ive owned my acclaim since 91, and I pretty much know what I am talking about. It would be pretty damn hard to install keylessentry for any model acclaim, or any electronics besides the sweet sterio system. Also where did you hook up the power *red* wore from the amp to? If hooked to battery it might be preventing enough amps going to the starter to crank. Try cranking it if no crank, its most likely the wrong place to hook it up, or the starter is faulty. No offence to anybody im only trying to provide some expertise here
MILLSDE
  • PLYMOUTH ACCLAIM
I have a 1993 plymouth acclaim
two days ago, I drove it just fine to my friends apartment
he and I went out of town (using his car) that evening and the next afternoon when I attempted to start my car all I get is a click
i don't know if the gas line would be frozen considering the high around here has been approximately 7 degrees
but i'm hoping to look for some insight on this
i know it's not the battery because my lights and radio all turn on when go to get in the car or turn the key, I did run the test to read the ECM on it and the ECM came back fine, so there's no failures recorded to the computer
and if it is the gas line, what is a quick, inexpensive method to get the car to start (there are no garages around here either)
Friday, July 24th, 2020 AT 6:20 PM (Merged)
GARFIELD
  • 197 POSTS
Just because the battery will turn everything on inside the car when you turn the key, the starter is one of the biggest electrical draw on the battery so it could still be the battery, try jump starting the car, if it jump starts your battery is probably the battery. Have your battery and alternator tested at one of the local auto parts stores like advance or autozone. Check both to make sure that your alternator did not die and kill your battery.
NECIA
  • 1991 PLYMOUTH ACCLAIM
1991 Plymouth Acclaim 4 cyl Two Wheel Drive
MY CAR TURN OVER BUT NOT FIRING
CARADIODOC
  • 33,752 POSTS
What have you checked so far? Is the Check Engine light on? If there is no spark, suspect the Hall Effect pickup assembly under the rotor in the distributor.
Caradiodoc
DESCHUTES606
  • 4 CYL
  • FWD
  • 116 MILES
I was hoping someone could help me out with my 1991 Plymouth Acclaim will not start. I turn the key over and it makes no noise but the check engine and oil lights come on. The windshield wipers still come on but the car does not start. Please help me! Thanks for your time.
Hi deschutes606, Welcome to 2carpros and TY for the donation
Start by making sure the battery condition and connections are good.
If okay check and test the orange fusible link at rear of battery,starter relay and ignition switch. See Starting system EWD below
https://www.2carpros.com/forum/automotive_pictures/12900_s1_42.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_s2_39.jpg
MISSMAC_33
  • 9 POSTS
  • 4 CYL
  • FWD
  • 178,825 MILES
My acclaim recently stopped starting for me. When the key is turned to on I don't hear the fuel pump kick on, but the very first try to start it the vehicle starts up but won't stay started, and then after that try it will turn over but not start. Does this mean my fuel pump needs to be replaced or something simple I'm missing?
JDL
  • 16,098 POSTS
How long since a tune-up? Any applicable mil codes? You can check those codes yourself. If cranks good but won't start, have a helper crank it while you visually check for spark at the plugs, if you have spark everywhere, use a gage and check fuel pressure.
To check for codes, you turn the key till the dash lites come on, no further. You cycle the key, on--off, on--off, on, then the mil starts flashing, you count the flashes to get the codes. Your looking for two digit codes.
MISSMAC_33
  • 9 POSTS
Well the code I got was 41 and 55. I called an auto store and they told me it means I have a charging issue, most likely with my asd relay.
JDL
  • 16,098 POSTS
Did you visually check for spark at the plugs? Engine cranking, anything? If the battery has a full charge and the vehicle is cranking ok, I'm not worried about the charging system, at the moment.
If the computer doesn't see an rpm signal it may not ground the asd relay. I, d look for rpm signal first.
To visually check for spark at the plugs, take spark plug wire loose from spark plug, use known good spark plug or spark tester in boot, ground metal part of tester to metal part of engine, watch for spark, engine cranking. Let us know.
MISSMAC_33
  • 9 POSTS
Yes I visually check the spark plugs and there is spark. The engine cranks and fires onces but wont fire again and just cranks. How would I look for an rpm signal?
