2CarPros - Car Questions & Answers
2001 Oldsmobile Silhouette Repair Question
Topics covered: Engine, Fuel pump, Battery.
Asked on March 8, 2009
2001 Oldsmobile Silhouette Hot Starting
Engine Performance problem
2001 Oldsmobile Silhouette 6 cyl Front Wheel Drive Automatic 84000 miles
My van starts fine when cold but after running for a while it doesn't start easily. Engine turns over well so I don't think its battery related. It sounds like not all cylinders are firing because it stumbles up to idle rpm and rolls over and dies. I have to wait about 15-30 minutes before I can start the engine. I've replaced fuel filter. Still same problem. Van has 84,000 miles with original plugs and wires. Someone suggested the fuel pump could be the issue or dirty fuel lines. Any ideas?
Avatar Asked by raiderfan10
Answer
Replied on March 8, 2009
Hi:
First, if the wires and plugs are original, I would perform a tune up. Also, the fuel pump could be an issue. What I recommend is to perform a fuel pump pressure test on it. Here is a "How To" video that will explain how to do it and what to look for.
http://www.2carpros.com/dia/test_fuel_pressure.htm
Many parts stores will rent or lend a gauge to you or you can purchase one at the test equipment store site on this page.
Finally, has the check engine light ever come on and does the temp gauge work properly in the car?
Tiny Answered by Jacobandnickolas (expert)
57,318 answers provided
