Mechanics
BATTERY OCCASSIONALLY DIES
1997 Nissan Maxima
Electrical problem
1997 Nissan Maxima 6 cyl Front Wheel Drive Automatic 66,000 miles
If I don't drive my car for a day or two it will not crank. When I jump it it cranks up okay and continues to crank okay if I use it on a regular basis. But when left for a day or more it will not crank.
I've had the Nissan dealership run a thourough diagnostic on it and the battery, alternator and starter are all good. No one at the Nissan dealership can find the problem. There also doesn't appear to be any lights on when left unrunning that might cause a slow drain.
There are two items that coincide with when the problem started. First, my wife plugged in a phone charger that blew the fuse and second, I changed out a rear brake light that had burnt out about the same time the problem started
Thanks for any help or direction you might be able to provide.
Chris86
December 17, 2007.
You have an electrical short that is more than the normal draw for memories-such a radio/clock etc, that's draining the battery overnite.
You might want to do another load testing on the battery and alternator to confirm that its functioning correctly.
Rasmataz
Dec 17, 2007.
AD
