Mechanics
AIR CONDITIONING STOPS COLD AIR
2003 Mitsubishi Lancer
Air Conditioning problem
2003 Mitsubishi Lancer 4 cyl Front Wheel Drive Manual 95,000 miles
my problems is that went I turned my a/c on its works perfect but after a while, its stop cooling specialty in hot weather, as long the compressor its working (engauched) no problem. But went it desingauched thats the problem.I hope you guys have an answer for this. Thanks a lot
Evega21
January 11, 2008.
Hi there.
Have the A/C pressures checked there may be a problem or it is getting low on refrigerant and the low pressure switch is kicking in shutting down the system.
Mark (mhpautos)
Mhpautos
Jan 11, 2008.
AD
