Fuel pump not working
RENEE ASHLEY
  • 2003 KIA OPTIMA
  • 2.4L
  • 4 CYL
  • 265,000 MILES
Wondering what could be wrong with my car, i'm a female who knows computer an tech swtuff not to much on cars sadly. Looking here I see possibly the fuel pump relay an can sensor could be the problem.
Friday, September 18th, 2020 AT 6:08 AM
  • 52,797 POSTS
Good morning,
Let us start with the issue.
What exactly is wrong? Does it not crank? Does it crank and not start?
I attached the control relay for the fuel pump. It is behind the right side of the dash
Friday, September 18th, 2020 AT 6:34 AM
MECHANIC2001
  • 2001 KIA OPTIMA
Where is the fuel pump emergency switch on a 2001 kia optima. Also, why wouldn't a fuel pump get fire from its relay?
Monday, January 25th, 2021 AT 11:01 AM (Merged)
  • 108,192 POSTS
There is no emergency switch. As far as the pump, if you have checked at the pump and there is no power and the fuel pump relay is sending power, there has to be a break in the wiring.
Check the ecm control relay and the ecu relay fuse to include the ignition switch.
