1989 Jeep Cherokee Repair Question
Asked on December 11, 2006
1989 Jeep Cherokee.
Jeep starts fine but will not idle. If I disconnect the vacuum tube to the map sensor, it will idle fine until the thermostat opens up and then it will stall. The map sensor and the ecm are new. The egr valve is not stuck. The fuel pump is also new and the injectors have been serviced.
Answer
Replied on December 11, 2006
Hey al,
Your symptoms lead me to say that its possibly a coolant temp sensor.
Regards,
Chris
