Brake pedal pushes almost all the to the floor?
LAELLIS
  • 1998 ISUZU RODEO
Brought my 1998 Rodeo to the Isuzu dealership about 2 weeks ago because the brake pedal when you apply pressure moved almost to the floor. Was told initially that it needed a new brake booster. Told them OK replace. Truck won't be ready till the next day because they needed parts. Got called next day and was told that they found that the master cylinder had a "small leak" when they bled the fluids out and that would need replacing. Sd OK, go ahead. When I picked the truck up was told I would see a big difference in how the brakes/pedal felt. Boy I sure did! When I touched the brake pedal I thought I would go through the windshield.
Drove truck home no problems. Next day took it out. After driving few miles I was having difficulty getting truck to drive forward when I pushed on the gas pedal. Truck just about stopped when I let up on the gas. Called the dealership back while I was driving was told to bring truck back in. Told them no way goiing to make it. I would have it towed. Went right home and by the time I got there I had smoke coming from under the truck, wheels/rims burning hot to touch.
Had towed to dealership. Got call from them saying that because master cyclinder wasn't working properly for awhile that my rear brakes were not being used to their full extent. Rust got in there and because the master cyclinder is now working properly the rust is being pushed through and causing the brakes to freeze up. I would need new rear brakes. They said I have about 2-3mm left on the pads.
They said they checked the front brakes and they are OK. They were able to free up the brakes and it was OK to drive but I should not wait past my next oil change. They said they noticed the rust when they worked on my truck but did not mention to me-forgot. I called two mechanics who both said they think they did not adjust the free play after replacing the master cyclinder. They wonder if I even needed the brake booster replaced. The dealership told me you can't adjust free play with disc brakes.
Now the brake pedal is acting like it did before I brought it in to have it fixed 2 weeks ago. Any idea what may be going on? I was told by the dealership that it isn't fair to ask opinions of other mechanics when they were not the ones who were working on the car to see exactly what was going on.
Opinion? Thanks
Sunday, October 5th, 2008 AT 4:51 PM
  • 108,269 POSTS
They are correct when they say you can't adjust free play on disc brakes. If the brakes were smoking, something was stuck. Did they replace rear calipers? This guide can help us fix it
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Sunday, October 5th, 2008 AT 10:10 PM
LAELLIS
  • 8 POSTS
Hi Joe,
Thanks Joe for your quick response.
I did not have them replace the rear brakes. I was too angry. All they did was free up the brakes so it could be driven. I still haven;t replaced the rear brakes because they said I still had more time with 2-3mm left on the brake pads. The truck hasn't been driven much since I got it back- maybe 3-4x. But it will be driven alot now because my son will be using it. He drove it home yesterday and felt that I did that the brake pedal feels just like it did before I brought it to the dealership. I am not sure if smoke was coming from both rear brakes but definately from the passenger side as well as the front passenger side. When the tow truck driver came to my house( within 10 minutes of me calling) he asked me when I last drove the truck because all 4 wheels plus rims would burn someone to the touch) plus he said the caliper on the passenger front was blue. When I told dealership about the blue caliper their response was it can be blue anyway from heavy breaking and not just from heat. They said front brakes OK- no warping.
Monday, October 6th, 2008 AT 3:57 AM
  • 108,269 POSTS
It is common for brakes to get hot; however, not as hot as you described, and they shouldn't smoke. At this point, I'm not sure what to tell you. I would have them check the e-brake for the rear brakes. As far as the front, I wonder if it could be caused by a bad rubber brake hose. After some years / miles, some rubber hose breaks down and allows fluid to go in one direction and not the other (which causes the brakes to stuck). At this point I would have to suggest for you to give them another try. Plus, they have to fix it. Keep in mind, if you don't like the car at this point, they only get three chances to repair a problem like this. It can be dangerous for the "driver to run the vehicle. If they don't fix it in three, I would fight it inder the lemon law and force them to take the vehicle back.
Good Luck,
Monday, October 6th, 2008 AT 10:12 AM
LAELLIS
  • 8 POSTS
Hi Joe.
Brought my 1998 Rodeo back to the dealership as you had suggested and they cannot find the reason why my brake pedal still goes to the floor. If you pump the brake will come back up. They said they tested the new brake booster and master cyclinder they put on it. Did a gravity bleed on it. Both test fine. They are perplexed. Said it wasn't a hose problem. Couldbn't find a leak or blockage. Have no idea. Said they had a another customer recently with same problem- different technician worked on vehicle. That customer is driving their rodeo and just being careful when braking. For me, it seems too dangerous now that winter is approaching. Any ideas?
Thanks.
Tuesday, October 14th, 2008 AT 11:09 PM
  • 108,269 POSTS
Hi:
If they checked everything and it's good, then the brakes should work properly. If the pedal goes to the floor, I would not drive it until it's repaired. By any chance is there an Isuzu dealer near you? If so, I would ask them to diagnose the problem and determine the problem. If they can fix it, I would try to have the place it's at now pay for it. If they are giving you a warranty and can't fix the problem, they need to find someone who can.
Let me know how it goes for you. I'm anxious to hear what the real problem is.
Wednesday, October 15th, 2008 AT 9:14 PM
LAELLIS
  • 8 POSTS
Hi Joe.
I spoke with the dealership again yesterday. They still have my truck. I spoke with another technician who suggested the problem may be a malfunction with the anti-lock brake system- specifically the electronic part of it. The dealership told me they had been focusing solely on the hydraulic part of the system. I emailed them the repair manual that the other technician emailed to me on how to check this problem.
I am hoping this is the answer. Will let you know. The dealership is anxious to check out this possibility. Will try to work on my truck today.
Thanks for replying. I will let you know the outcome.
Thursday, October 16th, 2008 AT 4:46 AM
MERLIN2021
  • 17,250 POSTS
I guarantee that free play at the pedal WAS adjusted this way, But you have a leak somewhere in the system, with 205,000 mile, your calipers need inspection for fluid passing by the seals.
https://www.2carpros.com/forum/automotive_pictures/62217_Freeplay_1.jpg
I believe the dealer adjusted too high and caused the brakes to drag.
Saturday, October 18th, 2008 AT 1:07 PM
LAELLIS
  • 8 POSTS
Hi Joe,
The dealership checked the ECHU harness and said that wasn't it as another technician I spoke to suggested we check. As far as free play goes, I have disc brakes and I guess you can't adjust free play with disc brakes only drum. The dealership did say that they tried to adjust the brake pedal but when they do it puts too much drag on the brakes. I asked them if all the calipers checked out OKAY.
Reason being is because I had to have the truck towed to them the day they replaced the master cyclinder and brake booster because rear brakes locked up. I hear a loud bang from the back of my truck and their was smoke coming from rear. I asked if because of that if their could be a problem with the calipers and they told me no. I think the technician that has been trying to figure out the problem has been looking at the truck for too long and is missing something. My husband is going to take the truck elswhere for another opinion. Just to let you know they retested the new master cylinder and brake booster and they both check fine. Any other suggestions, please let me know. If we ever find the problem I will let you know.
Thanks
Sunday, October 19th, 2008 AT 5:07 AM
MERLIN2021
  • 17,250 POSTS
Did you read my post? Pedal freeplay is adjusted by adjusting the pushrod, if done wrong SEVERE brake drag WILL occur! This is true for disc and drum brakes!
Sunday, October 19th, 2008 AT 8:41 AM
LAELLIS
  • 8 POSTS
Hi Joe,
I am sorry. I did not see the last line you wrote after you sent the instructions about adjusting the pus hrod. I will assume then that the technician may have adjusted the push rod too much initially and that's why when I stepped on the brake pedal it felt like I was going to go through the windshield? Would that be the reason the brakes locked up? They said it was because rust got into the brakes because the master cylinder wasn't working properly and the rear brakes were not operating at full efficiency. When it was replaced and working properly the brakes were now working properly and it pushed rust into the brakes causing the pads and rotors to stick together. When he freed the rear brakes, the pedal was soft like it was before.
They did say when I picked the truck up the other day that they did try to adjust the pedal and if they adjust too much it put drag on the rear brakes. When my husband drove the truck home from the dealer he said he could tell the pedal was adjusted but still had the problem of the pedal soft to floor.
Sunday, October 19th, 2008 AT 9:17 AM
RACEFAN966
  • 5,029 POSTS
If there is incorrect freeplay it can not be adjusted at the pedal. It is adjusted with the rod between the booster and the master cylinder. This should have been set by the remanufacturer of the part. Now did they order a booster and master together or seperatly? I would day that one or the other are bad. It don't happen to often but from time to time you get a bad unit from the rebuilder.
Monday, October 20th, 2008 AT 5:56 PM
LAELLIS
  • 8 POSTS
Hi Steve.
Yippee! Problem solved. My husband took the rodeo to another repair shop ( not dealership) and they replaced all four brake pads and found that the caliper on the front passenger brake was stuck to the pin because of corrosion. My husband said the brake pedal feels normal now.
Thought you may like to know because you have been so great about helping me try to find reasons for the problem. I had asked the dealership when I picked my rodeo up after the rear brakes locked up if they had checked the front brakes and the technician said he did. But obviously.
Thanks again. Have a great weekend.
Friday, October 24th, 2008 AT 4:55 AM
LAELLIS
  • 8 POSTS
I'm sorry I addressed you as Steve, not Joe. Its 6:00 am and I haven't had my coffee yet. I was speaking with my brother about the rodeo last night and his name is Steve.
Friday, October 24th, 2008 AT 4:57 AM
  • 108,269 POSTS
Great news!
Good luck and in the future if you have any questions, let us know.
Friday, October 24th, 2008 AT 9:56 AM
RACEFAN966
  • 5,029 POSTS
It ok my name is Steve and it is great to hear you brakes are fixed. Sometimes it just takes another opinion on it because then you get another perspective on it too. Anything else just let us know glad we could help.
Friday, October 24th, 2008 AT 10:10 AM
