Turn signal flasher location
EMANPETERSON
  • 2005 HYUNDAI ELANTRA
  • 4 CYL
  • 170,000 MILES
Hello, I have purchased a new turn signal flasher for my car and can't seem to find where it goes. I have looked for diagrams and/or pictures online and there is nothing that is leading me in the right direction. I looked under the driver's side dashboard for a similar unit, but couldn't see one. Am I looking in the wrong place?
Thursday, June 6th, 2019 AT 7:12 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It is located in the passenger compartment relay box. I've attached a picture below and circled in red.Here is a tutorial showing how to test a relay:
Hope this helps and thanks for using 2CarPros.
Danny-
Thursday, June 6th, 2019 AT 1:34 PM
EMANPETERSON
Thanks Danny! I found it and got it replaced. Working fine now. I appreciate your help!
Friday, June 7th, 2019 AT 8:19 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,070 POSTS
DANNY L is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
Monday, June 10th, 2019 AT 2:21 PM
DANNY L
  • 5,648 POSTS
You're welcome ! Thanks for using 2CarPros. Thanks for the compliment Ken.
Danny-
Monday, June 10th, 2019 AT 3:41 PM
SHERMAN4702
  • 2000 HYUNDAI ELANTRA
  • 4 CYL
  • FWD
  • 102,000 MILES
Where is the flasher unit on the 2000 hyundai elantra? Is it a regular after market unit (shaped like a cylinder- 2 prong).
Friday, August 21st, 2020 AT 6:54 PM (Merged)
ZACKMAN
  • 4,202 POSTS
In under the dash fuse box or Relay is located behind the glove box or Found turn signal flasher above steering column on drivers side.
https://www.2carpros.com/forum/automotive_pictures/55316_fl34_2.jpg
ABSDAD0621
  • 1999 HYUNDAI ELANTRA
  • 4 CYL
  • FWD
  • 179,200 MILES
The turn signals dont work. I checked fuses, the hazard flasher, all bulbs, put in a new switch and still no luck. I cant locate any info on the turn signal flasher. Any help would be appreciated. Thank You
BUDDYCRAIGG
  • 2,262 POSTS
You only have one flasher, for both the turn signals and the hazard flashers (m16). Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
ABSDAD0621
Why do the flashers work but not the turn signals. The flasher switch doesn't stay in place when you push it. You have to hold it in. Are the switch and signals connected
BUDDYCRAIGG
  • 2,262 POSTS
Now that you say that, it sounds like the multifunction switch is broken.
MATTHEW FOUNTAIN
  • 1998 HYUNDAI ELANTRA
  • 4 CYL
  • 160,000 MILES
Installed new sockets but now no turn signals or flashers.
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
I've attached pictures below of its location as you requested. It's located in the passenger compartment relay box in location #M18. I've circled in red. Hope this helps and thanks for using 2CarPros.
