Check engine light?
JANGELO641
  • 2002 FORD TAURUS
  • 6 CYL
  • FWD
  • 86,000 MILES
I just purchased a 2002 Taurus SES with 86,000k. I test drove this vehicle twice and had no problems at all the car seems to be rnning great and passed emmissions yesterday after replacing the batter and driving it around for a while to reset. The check engine light came on this morning, but still is driving very well. Any thoughts?
Friday, September 24th, 2010 AT 9:04 AM
WRENCHTECH
  • 20,758 POSTS
The "check engine" light is an indicator for a system that monitors many electronic functions in the system, also called the "malfunction indicator lamp" (MIL). It can come on for any of hundreds of different causes from any of the systems that the computer monitors. Some are very important and can lead to further component or engine damage and some are emissions related not as serious but still a problem and need to be repaired.
Your first step is to have the computer scanned to retrieve the trouble codes that were set when the check engine light came on. This guide can help us do that
Friday, September 24th, 2010 AT 9:08 AM
IDOPRAISE
  • 2002 FORD TAURUS
  • 6 CYL
  • FWD
  • 105,332 MILES
My car stutters/hesitates. The check engine light came on, the stared flashinh, then just stayed on.I tightened the gas cap and the light went out, but came back on. Car will drive but then it stutters and feels sluggish. I had a testing done on it. The possibilities were vacuum leak, high/low fuel pressure (whatever that means) or bad spark plugs. What do u think?
Saturday, October 24th, 2020 AT 11:46 AM (Merged)
MERLIN2021
  • 17,250 POSTS
I think the actual codes would help us determine where to start, but I always go with the basics first, when was the last COMPLETE tune up? All filters plugs and wires? When the MIL flashes, it means damage to the catalytic converter can be occuring!
TIGMANNC
  • 2002 FORD TAURUS
Engine problem
2002 Ford Taurus V6 Front Wheel Drive Automatic 137000 miles
2002 Ford Taurus wagon 3.0 V6_mileage: 137000. Several months ago our alternator went bad. I replaced it but a week later the check engine light came on and the car lost power while running VERY rough. I replaced the plugs, wires and coil pack. This significantly improved the problem however it still runs rough at idle. Especially with a load on (in gear or A/C on). The highway miles are still close to 27 mpg.
I checked the engine codes and they are P0302-Cylinder 2 Misfire Detected and P0316-Misfire Detected 1st 1000 Revs.
Generally there is no loss of power unless the car idles for a awhile after it is warm, ie at a stoplight. Then the check engine light begins to flash and power drops noticeably. If I ease the car along or let it sit long enough, the power returns and the light stops flashing. I suspect the #2 injector but I would like a professional opinion. Thank you.
Saturday, October 24th, 2020 AT 11:47 AM (Merged)
MERLIN2021
  • 17,250 POSTS
Yes you can check the injectors, all you need is an ohm meter, and a fuel pressure tester, here'sa how, the system by the way should be 39-65 psi...
https://www.2carpros.com/forum/automotive_pictures/62217_Injectors_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_Injectors1_1.jpg
KOCHANHS
  • 25 POSTS
  • 2002 FORD TAURUS
I am wondering when I should use a code reader to diagnose my car troubles.
Thanks.
BRUCE HUNT
  • 3,753 POSTS
Every time that Check Engine Light makes an appearance. It goes on for a reason, the car may still function properly but the code is telling you something worth listening to. It could be errant but it could be valuable as well.
BRYTSCAR
  • 2002 FORD TAURUS
  • 6 CYL
  • FWD
  • 166,000 MILES
The car is starting to be sluggish especially going up any type of hill. The engine light has now come on
JGAROFALO
  • 489 POSTS
Since your "check engine" light has come on, I would start by checking for codes. Your problem could be a failed sensor. Do you have any other symptoms? Like rough running, stalling, missing, etc?
Generally, performance problems are caused by mixture or ignition problems. The main mixture controls are the O2 sensors and the mass air flow sensor. A failed mass air flow sensor can go "undetected" by the computer for quite a while.
PAMELA44
  • 2002 FORD TAURUS
  • 6 CYL
  • 96,000 MILES
When driving on the freeway at approx 65 mph with the a/c on, the check engine light starts flashing and it feels as though the car loses power but does not stall. I basically coast after turning of the a/c and after a couple of minutes the light will stop flashing and the car drives normal.
This only happens on hot days when I am running the a/c. Please help! It's hot here!
Saturday, October 24th, 2020 AT 11:48 AM (Merged)
JERRYSHELL
  • 2002 FORD TAURUS
Engine Performance problem
2002 Ford Taurus 6 cyl Front Wheel Drive Automatic 120k miles
my car was involved in a front end driver side accident which took out the rack and pinion, the rotor on left side, the strut and lots of fender parts! Now I got it back and the abs light is on for one! I know thats brake sensor proble I guess, but my real problem is the engine light came on and also the car seems like it hads a misfire problem! Sometimes it's ok other times it misses or something like that, and when I step on it to get on major highways, the car seems to hold back! I have to almost floor it to get it going fast enough to merge! Also once on highway when I step on gas she seems like it dies then picks up hope I made alittle sense! Thanks for ur help
BMRFIXIT
  • 19,053 POSTS
Need to have it back at the shop that did the work ask them for the codes
they should be able to give you the ABS and engine codes
let me know what do u have for codes
check it for tune up
check the coil
check PCV valve hose for vacuum leaks
CAPTJOHN
  • 2002 FORD TAURUS
  • 6 CYL
  • FWD
  • 75,000 MILES
I just noticed a problem with my 24 valve engine. When I step on the gas to accelerate suddenly the check engine light flashes off and on for about a minute, them goes out. The light seems to go out when I let off on the gas, but won't come back on if I do the same thing again. It's done it two days in a row, it just started doing this. It's not low on oil or anything like that. The car has been great up to this point, not a single problem. I was thinking it might be the TPS sensor, but not sure. I may bring it in next week to see if any codes come up. Any thoughts on this?
MASTERTECHTIM
  • 4,749 POSTS
No tps. If your light flashes it means there is a misfire real bad. Id check plugs and wires, most likely thats all it is. Feedback greatly appreciated.
CAPTJOHN
I think you hit it on the head. Checked the codes, none. Opened the hood and looked at the wires in the front, two were touching, I adjusted them so they no longer touch, I haven't had the problem since. I now realize that the two times it happened were on days that the engine was cold. The wires could have gotten wet when the cold engine warmed up some, when they passes through the dew point, and it wouldn't do it again because the engine and wires were now warm, no longer wet. Thanks
LINDADIARTE
  • 2002 FORD TAURUS
  • 6 CYL
  • 132,000 MILES
Check engine light on and will not pass emision test
MERLIN2021
  • 17,250 POSTS
First thing you need to do is have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
If it won't make it to Autozone, buy a cheap scanner, they can be had for 30-40 dollars, a good investment, since they cover all cars sold in the USA from 96 on.
If the light is blinking, it means engine misfires possible damage to the Catalytic converter. Service it right away!
PABLOS
  • 2002 FORD TAURUS
2002 Ford Taurus 6 cyl Front Wheel Drive Automatic 140k miles
I had a 02(ex girls) ford Taurus Heads gasket repaired/ work was guarenteed along with radiator. This was about 100 days ago, after back n forth with Mechanic he is going to run a diagnostic again. Engine light has been on ever since, At another garage I had computer run (diagnositic)It says MISFIRE now, same MISFIRE as it had before. He(phone conversations) is trying to tell me he doesnt think it is still head gasket.
Also, we did bring it back a few days after he was finished gasket job, he said engine light would go off, and the fuel injectors had problem. ( He ran diagnositic and mentioned possible injectors, etc)
The car has never been back to full power, it hesitates slightly from a stop (lacking power) (less gas mileage).
During our dialogue ( he brings up fuel injectors, and other things ) excuses.
We are bringing it in his shop in next few days to look at, with my supervision.
He obviously want to blame in on something else, not GASKET, How and What do I watch for, and protect my self? I am sure he wants to dig up more $$, and not repair the gasket. Of course it could be something else.
Thanks
paul
Saturday, October 24th, 2020 AT 11:49 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Scan for codes
cylinder s misfiring
any cylinder that is misfiring check for spark, wire and coil
check compression
low compression its a headgasket issue
if engine overheating its possible headgasket issue
coil not firing its not a headgasket issue
if asking for money to fix the problem
have it checked and repaired by a different shop (as it is obvious that you have no trust in them )
if its a headgasket then you can demand your money back,
and you have a good running engine and a receipt from a different shop backing your claim
JUJOY65
  • 2002 FORD TAURUS
  • 6 CYL
  • FWD
  • 60,000 MILES
Engine light came on and stayed on. Checked gas cap - o.K. What else?
