2001 Ford Taurus Repair Question
Driver's power window
2001 Ford Taurus 6 cyl Two Wheel Drive Automatic 95123 miles
The switch of the driver's power window is not working. The 3 others switches and windows are working. I'd like to open the window panel to check what is defective. I took off the 4 screws off the panel, but I'm afraid to pry it that I might break something. I need your advise, please.
Answer
Dont know if this is your problem, using a test light on the connector while you operate the switch is the only way to find out.
CONCERN Driver's window is inoperative. Testing has proved that the switch and window motor is ok. ANOTHER CONCERN It needs a computer because the one touch feature has failed. And it is expensive. And it has taken about three hours to figure this out. The computer is behind the fuse panel and thats another hour to change. Now this is upwards to $600 dollars for a fix. YUCK THEORY If you could save the customer a considerable amount of money and get it working without the one touch feature, you would impress the customer with your smarts. They can live with out the feature better than they can without the money. THE FIX The computer can be by-passed easily by cutting two wires and then do the by-pass. I've attached a picture and a diagram that lays it all out for you. A TIP. Admin. the taurus has the same wiring diagram from 96 to 2006 on power windows. Can you copy to those years and link together? Yeplot of clicking. Thanks ...............jake
Thanks for the information about the jumper .
Your fix worked like a charm .
Thanks so much , you really relieved a big headache .
merlin2012 you really got it together .
so do you cut the brown wire and attach it to the red wire leaving the 2 wires unattachedfrom where you cut them from this by passes it by attaching just the 2 wires red and brown correct
none of my windows are working from any switch the relay just clicks ive changes all relays and fuses are good will this fix all the windows or just the drivers side or will it help we have tested the motor in the drivers side and it is good i rolled it up with a battery charger using a couple jumper wires after taking the connector off we were getting fore to the switch and to the motor but it still doesnt work it has a new window switch to its like the window locks are on or something
