2CarPros - Car Questions & Answers
2000 Ford Taurus Repair Question
Topics covered: Blower motor, Heater, Clutch.
Asked on January 12, 2009
Blower motor resistor
Heater problem
2000 Ford Taurus 6 cyl Front Wheel Drive Automatic 90000 miles
where is the blower motor resistor located
Avatar Asked by bmessling
Answer
Replied on January 12, 2009
Manual A/C-heater system consists of heater core, blower motor, compressor, compressor clutch, condenser, evaporator, A/C cycling switch, A/C compressor relief valve, A/C clutch relay, A/C pressure transducer, vacuum controlled airflow control doors, pollen filter and ducting to distribute temperature controlled air. A/C system is a cycling clutch type with a fixed orifice tube. Manual A/C-heater system heats or cools vehicle interior depending on function selector position and temperature selected. See Fig. 1 .
http://www.2carpros.com/forum/automotive_pictures/266999_blower_1.jpg
BLOWER MOTOR RESISTOR
Blower motor resistor is located behind glove box, on evaporator housing. Blower speed is determined by current path through 3 resistor elements. During high speed blower operation, resistor elements are by-passed. A thermal limiter in blower motor resistor protects blower motor circuit. If resistor overheats due to excessive heat, thermal limiter opens, preventing current flow through resistor elements. Thermo limiter will open at approximately 250 °F (121 °C).
Tiny Answered by Dave H (expert)
13,680 answers provided
