1989 Ford F-350 Repair Question
Topics covered: Fuel pump, Fuse, Air filter.
Asked on March 30, 2008
1989 Ford F350 Fuel relay/eec relay power?
dorve 2 miles shut off, key to assy., 10 minutes later it won't restart. It will turn over like out of fuel{(theres fuel)dual tanks}. no power to inertia switch,pump,tank switch,...
it will fire using some gas on air filter though. replaced fuel relay, same problem. power to both eec & fuel relays is good. Has had similar starting problem after running in past, but usually fires within 15 seconds and cracking foot throttle 1/2". your thoughts?
Answer
Replied on March 31, 2008
Check the computer if its properly grounded- The computer energizes the fuel pump relay then power goes to the inertia switch thru the brown wire then fuel pump.
Check no.11 fuse in the fuse panel it powers the tank switch
