Mechanics
F150 4X4 WILL NOT ENGAGE
2000 Ford F-150
Electrical problem
2000 Ford F150 V8 Four Wheel Drive Automatic 144000 miles
The 4x4 will not make any sounds whatsoever when you switch to 4 high or 4 low. I bought the truck like this. Also the blinkers will not work unless the steering wheel is let all the way up.
Robby_boatright
March 31, 2008.
The 4WD concern may be due to a bad shift motor. I believe the 2000 had a constant drive front differential that only engaged in the transfer case. If the shift motor on the rear of the case does not turn, then you may need to replace the motor. Check for voltage at the motor and post back the results. Also the concern with the turn signals may be due to a bad connection at the rear of the multifunction switch. Remove the steering column shroud and examine the switch (it's the turn signal, wiper, dimmer, hazard switch).
Flexy5
Mar 31, 2008.
