Mechanics
F150 FUEL PUMP RELAY
1988 Ford F-150
Electrical problem
1988 Ford F150 6 cyl Four Wheel Drive Manual 110000 miles
on 1988 ford F-150 what is the proper way for checking the fuel pump relay and its wires to diagnos the problem. When I jumper 12v on the fuel pumps they run. Also the EEC relay clicks and turns on, from my understanding that is what sends volts to relay.
Lil_drummer2009
April 3, 2009.
To learn how to check a relay, check out our Popular Service Repairs page. A link is below for your convenience...
http://www.2carpros.com/how_to/how_do_i_check_a_relay.htm
To test the wiring you will need a volt meter.
Thanks for using 2CarPros.com!
AD
