2CarPros - Car Questions & Answers
1984 Ford F-150 Repair Question
Topics covered: Starter, Engine, Fuse.
Asked on February 26, 2009
1984 Ford F150 Will not Start
Electrical problem
1984 Ford F150 6 cyl Two Wheel Drive Automatic 87000 miles
I Have a 1984 F150 I have received from my Step Dad when he passed away several years ago. I have ben restoring it between deployments and ahve the same problem several times.
The engine refuses to start. it has appeared to be a starter problem and replacing it has cured the problem in the past. I recently replaced the starter only to have the truck start once then not start on several attempts later.
The starter has been replaced twice in the last couple of days with the same results. A large load on the electrical system and lugging of the starter until it refuses to turn or even make an attempt to start. The previous starter was tested and it spun the first test then locked up after that. It ws VERY hot when I removed it from the vehicle. The new starter does not get hot but still will not start. The battery is less than a year old and check's out good. When I try to jumper the starter solenoid it just chatters and the starter does nothing.
Answer
Replied on February 26, 2009
Hi:
Is sounds like another bad starter. When you tried to jump it, did it sound like the solenoid was jumping in and out? Is it the same brand as the last starter?
Tiny Answered by Jacobandnickolas (expert)
57,318 answers provided
Yes the starters are the same brand - NAPA Supreme - I had a problem after I installed the first starter about 4 months ago - The starter refused to shut off and I could not shut off the engine. I disconnected the battery cable then reconnected the cable and the engine started and ran fine after that. I have been told that it could be a faulty relay, soleinold or ingition switch. Also is there a seperate ignition relay other than the starter soleinold. The manual I have calls the starter soleinold a relay?
The soleinold just chatered when I tried to jumper it from the positive input side to the exciter post. The starter did nothing.
Thanks
Tiny Response from Daniel L. Wright
1 question asked
Hi:
there is only one relay mounted on the inner fender. This is a picture of it.
http://www.2carpros.com/forum/automotive_pictures/249084_relay_3.jpg
If the ignition switch was bad, the lights on the dash wouldn't work correctly if the switch was not in the correct position. Have you replaced the relay (solenoid) to try that? If you are getting power to the relay, then it should be sent to the starter unless the relay is bad. Does your starter have 1 or 2 wires running to it?
