Sometimes it may fail two or three time in the space of a few miles...and then may not do it for 100 miles or so. It seems like when you let off the fuel feed and in gear moving such as slowing for a stop sign or slowing for a curve perhaps applying a little brake...and on a downward slope either slight or 3% or more....the motor will not respond when you're pressing the fuel pedal. If down hill on a curve slowing it may or may not come "back to life" if you hit the fuel pedal a few times.....when approaching a stop sign you can hear the engine sputtering as if perhaps one or two cylinders may be trying to fire. seems it will quit sputtering and die when you stop...with the clutch in at this last gasp the RPM's will be jumping between 450 to about 900 or so...then dies. You can immediately start the engine and all is ok...idle back to about 1100 or 1200 with an occasional 900...acceleration is normal...........for sometime now and even prior to this (a year plus) problem there is a strong odor of gasoline when you stop, get out...and smell the air. I have popped the hood and looked and looked under the vehicle for signs of fuel...from front to rear and have found none. I have asked a mechanic and they find nothing...thanks Glen
Aug 2, 2014 at 1:54 PM
