My engine stalls while driving?
USAFWIFE2005
  • 1994 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 152,366 MILES
My 1994 ford explorer runs fine and then it stops running and all the power to the truck goes. We have tried the spark plugs and the cam position sensor and then we tried to replace the computer. And it still does the same thing. Do you have any idea what the problem could be?
Wednesday, December 19th, 2007 AT 9:42 AM
BHUGG
  • 157 POSTS
I had a similar problem with my 93. It turned out to be a faulty PCM relay. I would be driving along and the engine would die. After a minute, it would restart and go for a while. It is located in the power distribution box under the hood. Check with your owners manual for the location.
I found this guide that can help us fix it as well
https://www.2carpros.com/articles/engine-stalls
Wednesday, December 19th, 2007 AT 10:17 PM
DPMORROW1962
  • 6 CYL
  • 4WD
  • 180,000 MILES
I have a problem with my Explorer in that sometimes while I'm driving the engine will die. After it sits anywhere from 15 minutes to over an hour it will start. Additionally, after driving for a while and turn off the engine it won't start. If I raise the hood for 15 minutes to over an hour it will start again. I took it to a shop about a year ago and they indicated that it was the onboard computer unit. I had that replaced. The problem went away for a few months but started back again. Any suggestions?
Friday, October 9th, 2020 AT 11:43 AM (Merged)
BUDDYCRAIGG
  • 2,262 POSTS
What you are describing is indicative of an electrical component getting hot and failing. Often in the ignition system like a control module or coil.
Next time you get home after a drive and have some time to mess with it, try to restart it. If it wont start, pull a spark plug and verify that you have a good spark.
SQUARED
  • 6 POSTS
Engine Performance problem
1994 Ford Explorer 6 cyl Four Wheel Drive Manual?Broke miles
Hey guys, I have a 2004 ford explorer 4.0 v6 engine and dash in an 88 ranger with ranger drive train. Put together to be used as a mud truck for the past few years and has been beaten up on but dosent want to die. It drives pretty good for an old beat up truck
**My concern is that the engine has**
(1)very slight (idle mainly) misfire symptom,
(2)hesitates when accelerating from its set 600 rpm idle but pretty much smooths out after 2000- but no real hesitation accellarating from about 1000 rpm on up, (3)i THINK that most of the problem occurs once the check engine lite comes on(usually about a minute after starting).
(4)intake manifold is loaded inside with black greasy carbon stuff
**things I did to try and fix it so far**
(1) I changed the plugs, wires, and coil(checked and double checked wiring configuration so thats not it)(2) sprayed fuel injector/throttle body cleaner in throat(while off and while running-and wasnt really able to remove intake hose thing too far off throttle body throat without it stalling
(3)removed air filter-ran the engine-and reinstalled it(no change)
(4)removed MAF sensor plug while it was running and didnt hear a difference even when I revved up th motor(i think its called that-sensor right there with air filter?)
`really strange that it would stall when I pulled the rubber intake off the throttle body but not when I disonnected that sensor
Please help!- I dont want to dump more useless money into this old mud truck
Friday, October 9th, 2020 AT 11:58 AM (Merged)
JGAROFALO
  • 489 POSTS
Do you have the 2004 computer, wiring, and sensors in the Ranger? Is it the correct computer for the type of transmission you have? Is this a "new" symptom, or has it been this way since installation?
Next, I suggest that you put some diagnostics on the engine. This has the sound of a bad mass air flow sensor. Also, you should never clean the throttle body. Cleaning it will cause idle problems and hesitations.
SQUARED
  • 6 POSTS
In addition my fuel pump is an aftermarket electric external one being that this car origionally had a carbuerator and mechanical fuel pump it needed this different one. I checked the fuel pressure and factory(vaccum connected) pressure should be between 30-45 psi idle for this engine and I had 30 psi with the vac still hooked up to regulator, didnt check w/o hookup yet but it runs the same without it hooked up. Could that still be it, or maybe a bad injector or regulator? I also stalled out and to get going I put 2 gallons gas thinking that would get me going, but I had to disconnect fuel pump and turn over the engine and finally fuel started coming out from pump after about 10 seconds with the help of boosting the engine with a shot of either into the throttle body. Does that tell u anything. The computer scanning just gave automatic transmission codes(which was for the car this motor was origionally in)as well as one "EGR valve" code?-All with car on/engine off
JGAROFALO
  • 489 POSTS
You should definitely have more pressure in the fuel system. The system is designed to have a constant pressure across the injectors. With vacuum, the pressure will be lower, without vacuum, it should be higher. The reason for the constant pressure is for the PCM to calculate the proper duty cycle for the injectors to dispense the correct amout of fuel - without adding more variables.
Probably the reason you had to prime the system is that the PCM is apparently not controlling the fuel pump relay. The PCM is programmed to run the pump for a few seconds on power-up and turn it off until it "sees" an ignition signal to turn it back on.
The trouble codes you are getting are most likely the result of having a "hybrid" setup that the system was not programmed for. I would suggest that you start by getting a '04 PCM from a stick shift. This will eliminate the transmission codes. The EGR code could be coming from a problem in the wiring.
Keep in mind that the entire SYSTEM was designed and programmed for a different vehicle with a different type of transmission. Your task now is to satisfy the PCM. When the PCM is not happy, it goes into a default programming mode that is essentially a cold engine program. Performance and driveability suffer ein this mode. Simply changing parts is not likely to solve the problem(s).
SQUARED
  • 6 POSTS
Lol :). Thanks man, that sounds like were getting somewhere with the troubleshooting process. Very interesting, especially because, well, uh, there is no fuel pump relay in this rig!Lol I dont kno what the guys that built this thing were thinking, but this sounds like I should just make sure what I have is not broken/clogged in the fuel system(regulator, pump, ect.), And maybe put a cheap higher pressure pump in?And if that dosent work its probrably too much money to go any further on this thing huh?Just drive it to the ground? Also if I were to get an 04 manual computer, will it hook up properly to this 88 ranger gearbox? And what kind of 04 manual computer? 4.0L V6 ford anything(whatever that had this motor with a manual trans in 04?)
thanks again for your time helping me with this! I hope you tell me it will be worth it, and the pump could be a possible fix.
JGAROFALO
  • 489 POSTS
Well, why not start with the easier stuff first.
First thing you need to find is a reasonably priced DIY junkyard. We have them in my neck of the woods, not sure about where you are. Around here, a computer only runs about $10 to 20 if you pull it yourself. Any Explorer or Ranger computer from a 4.0 with stick shift should be OK.
A really good starting point would be to get a Haynes manual for the car that the engine came from. Look at the wiring diagram. You can get a used power distribution box and wire the thing yourself without too much complication. The important things are the PCM power relay and the fuel pump relay. There is a very good reason that the PCM controls the fuel pump - SAFETY! If you were to develop a fuel leak or be involved in a collision that compromised your fuel lines, the PCM will shut off the fuel. Without the relay and the inertia switch, the fuel keeps coming. If you try to restart at that point, without a safety system, you could potentially have the entire contents of the fuel tank leaking all over. One spark, and you have a "towering inferno"!
The loaded question is whether it is worth it. Only you can decide that. You have the potential for a good usable truck that can serve you for many years - assuming the rest of the vehicle is in good shape. Rust and general condition are the main points to consider.
BTW, fuel pressure is very important. The system is designed to operate on a predetermined fuel strategy that is programmed into the PCM. That is why there is a pressure regulator and a high volume/high pressure pump in the original. If you don't have the right pressure, nothing else you do will matter.
BARRYP100
  • 150,000 MILES
The vehicle will sometimes start and will drive for a while, sometimes the car will not start but the engine will turn over and run the battery flat. While driving the car will just stall out and then it wont start again till I jump it stalls out sometimes. Changed fuel filter and fuel pump. Car does turn over
Friday, October 9th, 2020 AT 11:59 AM (Merged)
  • 108,328 POSTS
I need you to check something. On the 94, there is a relay called the Electronic Engine Control (EEC). I have experienced people with the same vehicle saying they drive, it runs fine, they stop and it won't restart. If the relay is bad, it will shut down the fuel pump and spark to the engine. When it doesn't start, switch the EEC with another relay in the box that has the same part number. See if that fixes the problem. If it does, replace the relay.
BANDIT751
Engine Mechanical problem
1994 Ford Explorer Four Wheel Drive Automatic 174016 miles
The car will start and you can drive it but then it will die. If you wait a few minutes it will restart and you can drive it again. I replaced the fuel pump and that did not fix the problem, What should I look at next?
  • 108,328 POSTS
It sounds like a crank sensor. Have you actually checked fuel pump pressure? I realize it is new, but there could be an issue with the regulator. Has the check engine light come on?
JJUICE97
  • 6 CYL
  • 4WD
  • 162,000 MILES
I have a 1994 ford explorer. When we drove it, we gave it gas and it didnt want to go up the hill. Then it stalled. What do we need to look at first to replace or clean?
  • 108,328 POSTS
Based on your description, when going up a hill, there is more demand for fuel. Therefore, I would start by checking fuel pump pressure.
Here are directions for checking.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
You will need a fuel pressure gauge. Most parts stores will lend or rent them. Check that and let me know what you find. Also, let me know if the fuel filter has been replaced.
JJUICE97
Ok, we will start with that and see. Do you think that it would have anything to do with oxygen sensor, or mass air flow sensors? Is there a possibility that the cataliytic converter could be stopped up?
  • 108,328 POSTS
If the O2 sensor or MAF was bad, it would have set the check engine light. As far as the catalytic converter, that could be a problem. When the engine is running and at normal temp, look at the converter. Many times when they are plugged, they get red hot. If it is red, replace it.
RATHMAN 62
  • 6 CYL
  • 4WD
  • 218,000 MILES
Just read a post sounds like its close to miy prob. During hot weather it stalls I have to let it cool down to get going again which does'nt last long then it dies again. It was doing this last summer, when the weather cooled down it did not do it again then this summer came its back to doing it again, early morning or late in the evening when it cools it runs perfect, I know this might sound strange but thats whats happening, havethrew some parts at it with no success, scan tool is'nt picking it up, what part could have to do with outside temp? Anyone have any ideas? Will donate for the right answer. Thanks
RATHMAN 62
We got it fixed so anyone who is having same problem change out your crankshaft position sensor it fixed my problem and the part is'nt too exspensive $39 and change total at O' Reillys auto parts store. The sensor was'nt completly out it was weak so when it got hot enough it would cause truck to die.
FORD EXPLORER
  • 6 CYL
  • 4WD
  • 288,000 MILES
I drive a 1994 Ford Explorer with 288000km and a couple of weekends ago, I was driving on the highway (HDW401) and stopped off at a service station to get lunch. When I returned back to the truck about 10 minutes later the truck would not start. The engine would turn over, but did not start. I tried pressing on the gas pedal, but would not start. I called a tow truck and about 40 minutes later the tow truck showed up and then the truck started with no problem. I decided to drive the truck home and after about 1 hour on the highway with the cruise control set to 115km/h the engine stopped running. After a couple of minutes the engine started again but ran really rough. At this point I was only about 20km from home. I made it home but the truck stalled about 20 times, and each time the truck started again but ran really rough and making lots of engine noice. The next day the truck and ran without any problems, but I did not go far. What can I fix or replace to prevent this happening again?
