Wrench icon turned on
OMESWTMOM
  • 2010 FORD ESCAPE
  • 6 CYL
  • 4WD
  • 121,138 MILES
We are driving down the road now the icon that looks like a wrench came on in dashboard. What does that mean?
Friday, February 8th, 2019 AT 7:18 PM
  • 108,300 POSTS
This means the engine is having an issue in ford escape is a common problem indicating a bad Electronic Throttle Body.
This guide should help
We should run the codes
Friday, February 8th, 2019 AT 9:24 PM
2CP-ARCHIVES
  • 4,540 POSTS
  • 2010 FORD ESCAPE
  • 74,500 MILES
I recently got my truck scanned to see why I had a check engine light on. After it was scanned I got a code of P1450 I'm not sure what this means could you please help me out!
Monday, July 6th, 2020 AT 5:41 PM (Merged)
HMAC300
  • 48,601 POSTS
Capless fuel tank filler pipe damaged,  preventing vacuum relief (if equipped)
? Contaminated fuel vapor elbow on the EVAP canister
Possible ? Restricted EVAP canister
Causes: ? Canister vent (CV) solenoid stuck partially or fully open
? Plugged CV solenoid filter
? EVAP canister purge valve stuck open
? VREF circuit open in the harness near the fuel tank pressure (FTP) sensor,  the FTP sensor or the powertrain control module (PCM)
? Damaged FTP sensor
also fule cap stuck closed blocking vacuum relief.
MELINDATHEONEANDONLYBRIDGES
Earlier this afternoon I was stopped at a red light and it seemed like it wanted to stall but it didn't. After I got where I was going, I went into the store for about an hour started the SUV again and it didn't act up again but still had the engine light on. Would all of those cause my SUV to act up like that?
HMAC300
  • 48,601 POSTS
No the engine ligh is on because you need a scanner to shut it off after being fixed. Do yourself a favor and have apro fix athis for you it will be much cheaper in the long run.
JACKAZZ088
  • 2005 FORD ESCAPE
  • 6 CYL
  • 80,000 MILES
My girlfriends 2005 Ford Escapes started shaking and the check engine light came on yesterday, I scanned it and it had 2 codes P0305 and P0316, which when I searched them told me that the 5th cylinder was misfiring. I drove it back to the house and later that day cleared the codes and started it, it started and drove just fine and the code never came back on. I figured it was a fluke with the computer but it happened again this morning but this time we got six codes P0304, P0316, P0300PD, P0304PD, P0305PD, P0316PD. Where do I start?
Monday, July 6th, 2020 AT 5:42 PM (Merged)
Random misfires normally caused by vacuum leaks and contaminated fuel.
1.Defective spark plugs
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Manifold absolute pressure sensor
12.Mass Airflow Sensor
13.Idle air control valve
Note: If it doesn't apply disregard it-
LIGHTMAYO
  • 2005 FORD ESCAPE
  • 4WD
  • 91,000 MILES
2005 Ford Escape check engine light on Codes P0430 U0121 U0155 - What do these mean?
WRENCHTECH
  • 20,758 POSTS
The PO430 is low efficiency on the bank2 Catalytic Converter. The other codes are communication codes for the bus network that joins all the computers. That's not something you could deal with yourself. That takes some pretty expensive equipment to deal with those.
LIGHTMAYO
What is the estimated cost of repairs? Can I drive until repaired?
WRENCHTECH
  • 20,758 POSTS
I can't answer either of those questions. Too many unknown factors right now. You'll probably spend a couple hundred in diagnostics to get to the bottom of it.
MANDYGAIL08
  • 2005 FORD ESCAPE
  • 6 CYL
  • FWD
  • 83,000 MILES
The engine light is on and they said it was the 02 sensor and so we replaced it, but the check engine light cam back on! What should we do? How many sensors are on my truck and where are they located? We only repleced one do you think we replaced the wrong one? Also I hear a noise when I hit bumps under the hood on the driver side- its like something is betting or knocking on the hood of the truck, but its under the hood? Please help!
  • 108,300 POSTS
Check strut plates and sway bar links. Also, have the computer rescanned to determine if the code is the same. If it is, let me know the code so I can check into it.
TECUNUMAN1
  • 2005 FORD ESCAPE
  • 6 CYL
  • FWD
  • 66,661 MILES
I am very interested in buying a OBD II scanner, I have been getting mixed messages about different type's of scanner's, one person tells me that I need a OBD II CAN something, and the other says a ordinary OBD II is fine, something to do with when the car was made, any information would be a great help thank you. Cruz
BMRFIXIT
  • 19,053 POSTS
What you need it to do
just to read PCM codes
all will do that
this is a link to show you the difference between all
and how much are they
JAYBIRD_291
  • 2005 FORD ESCAPE
  • 6 CYL
  • 4WD
  • 40,000 MILES
05 Escape 3.0 6 cyl with CEL blinking. Codes as above and Ford dealership wants $400+ to repair. My question is: they said it was my #1 plug and ignition coil but the error code 353 is "Ignition Coil C Primary/Secondary Circuit Malfunction". What does this entail? Can I replace the plug and coil for #1 or is it more involved? Would like to save the $$$. Thanks.
2CARPRO JACK
  • 11,533 POSTS
The second code is most likely created by abnormal resistance in the coil circuit, which could be froma bad coil. The cyl1 misfire is most likely the bad coil. You can DIY this easily. You should however install factory parts, cheaper electronics are exactly that. Cheaper
AMALGOM
Had same problem on 2000 ford ranger. Replaced, spark plug and wires which were bad. Still got same error. Replaced coil pack. Still had error. Turned out to be caused by bad Power Control Module relay in power box. Replaced relay and no more error codes or trouble staring in humid weather.
KMBER07
  • 2005 FORD ESCAPE
2005 Ford Escape 4 cyl 84,000 miles
I have a 2005 ford escape. I purchased the escape brand new and still owe money on the car. I drove to visit my family which was about four hours away. I drove for a period without stopping, but when I went to stop, the car jerked/stuttered and then cut off. The check engine light never came on prior to this incident and still has never come on when the issue occurs. I was working on the repairs and have replaced some small things and had some sort of cleaning done on it, but now I cant drive a mile and the car stalls out when I go to stop. When the car stalls out, I have to start it back up and rev on the gas until I can go. Once I can go I have to very quickly put it into drive. I am concerned for safety reasons especially. I am not sure what the issue is and no mechanics can agree on the issue. I have found hundreds of similar complaints upon doing research and I guess what I really want to know is what the problem is?
  • 108,300 POSTS
Have you checked fuel pump pressure?
