Mechanics
TIMING BELT BROKE
2000 Dodge Stratus
Engine Mechanical problem
2000 Dodge Stratus 4 cyl Front Wheel Drive Automatic 139000 miles
I replaced the timing belt after it broke. Checked and double checked the timing I am certain it is correct. Car runs rough at idle and sometimes dies but runs smoothly when driving and RPM's are up. Performed compression test and found cylinders 1, and 2 at 205 PSI found cylinder 3 at 175 psi and #4 at 150 psi. My question is with the 2.4 DOCH engine in this Stratus is valve train damage all most certain. I am very familiar with GM but don't have much of experience with Chrysler products. I am a a soldier hwo just returned from Iraq and am fixing my car my self as I don't have allot of funds available.
Allen.keskinen
March 11, 2010.
Thank you for your service.
Yes, valve damage occurs when the belt breaks, but it is usually much more severe than simply running roughly. The compression readings suggest the valves aren't the problem. Did the belt really break or just jump a tooth or two?
If you had the battery disconnected, the Engine Computer will have to relearn minimum throttle. To meet the conditions for that to occur, drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the brake or gas pedals.
Caradiodoc
AD
Caradiodoc
Mar 11, 2010.
Yes the belt did break the engine was at idle in traffic.
Thank you for your insight. I have don nothing but city driving since the repair. I will give this procedure a try. Thanks again
Allen.keskinen
Mar 12, 2010.
Thank you for using 2CarPros. Com. We appreciate your donation and look forward to helping you in the future.
2CarPros Linsey
Mar 15, 2010.
AD
