Mechanics
FUEL FILTER
2002 Dodge Dakota
Engine Performance problem
2002 Dodge Dakota 6 cyl Four Wheel Drive Automatic 91,700 miles
I was wondering where the fuel filter is? And if it is easy to fix myself?
IRISHROB
July 14, 2009.
Hello, the filter/regulator shows to be an assembly on top of the fuel pump module in the gas tank. I looked at a couple of online partsbooks, they didn't show a filter/regulator assembly separate from the pump module. You might talk to your local partsdealer.
If you have to remove the pump module, you may have to drain and lower the tank.
JDL
Jul 14, 2009.
AD
