Horn not working?
JZAPOR
  • 2007 DODGE CALIBER
  • 4 CYL
  • FWD
  • 54,000 MILES
Just bought a uses 07 Caliber SXT and forgot to check if the Horn worked. Well it does not work from steering wheel, but works fine for the Alarm system. Does not appear to be the physical horn, but uncertain. Also fuse in slot 23 is fine.
Need Help! Thx.
Saturday, March 5th, 2011 AT 4:53 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,072 POSTS
The horn relay is located in the TIPM under the hood behind the front bumper on the driver side the tipm is where the fuses are. Here are some guides and fuse panel diagrams so you can do some quick tests if everything tests ok check the horn itself they go bad all the time.
and
Check out the diagrams (Below)
Please let us know what you find.
Cheers, Ken
Thursday, November 30th, 2017 AT 5:36 PM
HSTARNS
  • 63,000 MILES
My car horn does not work and I can't find any information in the owners manual regarding the horn. I am not sure which fuse is for my horn and can't find it under the hood either. Could it be the fuse needs to be replaced?
Thursday, November 30th, 2017 AT 5:37 PM (Merged)
Could be the fuse, horn button on the steering, horn relay or horn itself
FIXITMR
  • 9,990 POSTS
The horn itself go out all the time
This could be a horn issue but the way to check the entire system is to go to the horn and check for 12 volts on the single wire when the horn is being pressed.
If there is no voltage there, then you have a wiring issue or the TIPM has failed.
Both the horn and TIPM are common failures on this. However, to confirm this we need to monitor the cluster data with a scan tool and find out if it is picking up the button being pressed.
If this is then the button and the clock spring is okay.
Please see the wiring diagram for more information on this testing.
Let us know what questions you have. Thanks
Tuesday, October 5th, 2021 AT 5:22 PM
ROB ERT
Did you ever figure it out? I’m having the same problem on my 2010 model
Sunday, August 27th, 2023 AT 10:45 AM
KEN L
  • 43,072 POSTS
I would use a test light at the horn itself to see if the horn has failed. This guide can help, have a helper hit the horn for you. Use the wiring diagrams above to see what color wire it is, there is only one going to the horn.
Please go over this guide and get back to us.
Monday, August 28th, 2023 AT 9:45 AM
