Instrument Cluster?
BRENDAN.BOOSE
  • 1999 LINCOLN CONTINENTAL
  • V8
  • 163,200 MILES
I have a 1999 Lincoln Continental with floor shift. Recently, once I've been driving for a few minutes, the display to the left (MPG, Range, Etc.) Will start flashing with all sorts of hieroglyphs. The rest of the cluster's lights will flicker as well. Is this a problem with the cluster itself, or with the computer. And is the cluster replaceable?
Friday, December 3rd, 2010 AT 3:54 AM
  • 108,192 POSTS
That sounds like the cluster itself is going bad. And yes, it is replaceable. I am assuming this is a digital dash. If that is incorrect, let me know.
Friday, December 3rd, 2010 AT 3:57 AM
BRENDAN.BOOSE
Yes, it is a digital dash. I see that they sell them out of scrapped cars on ebay and they are guaranteed by the seller to work. Are there at least basic outlines on how to replace it, and do you think this would be a good way to go?
Friday, December 3rd, 2010 AT 4:04 AM
  • 108,192 POSTS
Based on your description, I would say yes. As far as replacement, disconnect the battery, remove the trim around the cluster, that will expose the screws that hold it in place. Remove them, remove the cluster, and then the wiring.
Friday, December 3rd, 2010 AT 4:57 AM
BRENDAN.BOOSE
Thanks for your help. I think I will do that. Almost certain it's the right one, just thought i'd have you take a look. Again, thanks for the help.
Friday, December 3rd, 2010 AT 5:08 AM
  • 108,192 POSTS
Let me know how it goes for you.
Friday, December 3rd, 2010 AT 2:45 PM
LARRY_S4
  • 1997 LINCOLN CONTINENTAL
1997 Lincoln Continental Front Wheel Drive Automatic
i had a surge and bad battery so I chanced the battery now the speedodometer shows above 120 mph. It has a digital dash can someone tell me how to reset it so it will work again.
Thursday, August 27th, 2020 AT 10:46 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Will need diagnostic scanner and perform following steps..
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_2571.jpg
may want to try just disconnecting and reconnecting battery first..
SHAUNLEVINE
  • 1996 LINCOLN CONTINENTAL
  • 0.5L
  • V8
  • FWD
  • 146,000 MILES
So when I start up my Lincoln the gas gauge reads full and within a minute drops down to empty. The onboard Notification Center reads fuel level error. What could be causing this?
CARADIODOC
  • 33,742 POSTS
Bad connection on the fuel level sending unit. Usually the float arm can be removed and the spring-loaded contact can be bent to make better contact. The clue is the gauge will almost always work properly when the tank is at a certain level such as 1/4 tank or half tank, and it will be pretty consistent. Another potential clue is if the gauge starts working again for a minute or two after going around a corner. That makes the gas move to one side of the tank and the level can change at the sending unit.
CHRIS BLOSS
  • 6 POSTS
  • 1994 LINCOLN CONTINENTAL
  • 6 CYL
  • FWD
  • 113,000 MILES
Does the electronic dash enterchange between the signiture series and the exutive series on a 1994 continental
Thursday, August 27th, 2020 AT 10:47 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Yes make sure it's same year and has same type of shift (column or floor shift).
CHRIS BLOSS
  • 6 POSTS
Thanks for the info you guys sure help out my next step is a repair manuel to disasembale thanks again
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_2297.jpg
TOM MERCELL
  • 6 CYL
  • FWD
  • 160,000 MILES
My dash gauges are all digital and my DLC keeps coming on where is it located?
JOEPETERSON56
  • 5 POSTS
DCL or Diagnostic Connector Link is located in the trunk on the left side, behind the carpeting right where the rear left tire wheel well starts up from the trunk floor. There should be an opening in the carpet and the wire is pined to the metal support plate there. Als mounted just below that is a switch for the air ride suspension, as well as the fuel cut off switch.
JAMESF977
  • 1993 LINCOLN CONTINENTAL
  • 6 CYL
  • FWD
  • 164,000 MILES
I have replaced all bulbs, fuses and buss strips. And still the dashboard lights won't light up
PROMECHANIC
  • 536 POSTS
I would be looking at the wiring from the gauges to the panel lights. It sounds like there might be a problem in this wiring. You can use a voltmeter to check and see if they are getting voltage.
CJ MEDEVAC
  • 11,004 POSTS
THIS "MAY" HELP.I PLUGGED IN '93 CONTINENTAL "EXECUTIVE", IF THIS IS WRONG, LET ME KNOW. THIS MAY BE THE WRONG DIAGRAM
THIS DIAGRAM IS "INSTRUMENTATION ILLUMINATION" THERE ARE MANY OTHER DIAGRAMS FOR YOUR CAR. IF YOU WANT SPECIFIC ONES, LET ME KNOW.I'LL TRY!
I NEVER KNOW IF THEY ARE LEGIBLE ON SITE, UNTIL I POST THEM, LET ME KNOW IF YOU CANNOT READ 'EM, I CAN EXPLAIN HOW I CAN GET THEM TO YOU SAFELY, WITHOUT BROADCASTING YOUR EMAIL ADDRESS ON OPEN FORUM
promechanic,
WHEN I GOT GOING HERE, I WAS SORTA LOST. STILL AM, MOST OF THE TIME! YOU MAY ALSO BE ENTITLED TO USE MITCHEL I, SORTA A "SPIFF", FOR ANSWERING HERE, TO GET THESE DIAGRAMS. YOU MAY ALREADY KNOW THIS, IF NOT, CONTACT "MIKE" HE'LL GET YOU IN GEAR FOR IT. LET ME KNOW IF I CAN HELP YOU AT ALL.
THE MEDIC
GAMBLERR
  • 23 POSTS
  • 1992 LINCOLN CONTINENTAL
I have been having a problem for the past 5 years with my gauges on my dash. They are all digital readout units. My oil pressure gauge will all of a sudden drop to one bar, and the alarm goes off, but I have found that the pressure is fine, using a manual gauge, also, if I hit the top of my dash, over the gauge, it will then read fine, for a short while, and then start to act up again. Some times it will work fine for hours. I also have the same problem with the read out on the right side of my dash, the one that shows distance to empty, trip mileage, etc. That also will keep dropping out and give me the DCL light, to say it is not getting any info. I have pulled my dash, to see if I could find any loose connections, but so far have found nothing. Any ideas?
Thank you
LOSONE
  • 1,616 POSTS
Common problem. Replace the cluster with a rebuilt. It is one solution. There is a remote chance that it may be the voltage regulator module on the back of the cluster asembly.
