Fuel filter
KIMMEL69
  • 2005 CHEVROLET MALIBU
  • FWD
  • 87,000 MILES
Where is the fuel filter? And how do I change it?
Tuesday, August 26th, 2014 AT 2:49 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,959 POSTS
The fuel filter is in the tank and is considered a lifetime filter. But like all filters get plugged up. It is called a strainer
Here is a guide to show you what you are in for when replacing the fuel filter.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Check out the diagrams (Below)
Cheers, Ken
Tuesday, August 26th, 2014 AT 3:17 PM
KIMMEL69
But when I start my car I need to push the accelerator. Doesn't that mean the filter needs replaced? Or are u saying the fuel filter is always good and it's something else.
Tuesday, August 26th, 2014 AT 6:29 PM
KEN L
  • 42,959 POSTS
It sounds like you need to service the throttle bore, Here is a guide to help you see what you are in for when doing the job.
Please let us know what you find.
Cheers, Ken
Tuesday, August 26th, 2014 AT 7:38 PM
KIMMEL69
Wow thanks that did the trick I love this site!
Friday, September 26th, 2014 AT 9:28 PM
MYSTIC117
Engine Performance problem
2005 Chevy Malibu 6 cyl Automatic 86,000 miles
When do I need to change my fuel filter? The oil change guy said I need to change it every 30,000 miles, but my dad said modern cars don't need them changed unless there is a problem. Who is right? My manual doesn't say anything about changing the filter at all.
Thursday, January 24th, 2019 AT 6:15 PM (Merged)
SERVICE WRITER
  • 9,123 POSTS
Who is right?
Both are right.
Here is the problem. You have a filter in the tank that is capable (so the engineers say) of long term filtration qualities. It is not cost effective to replace yours on a maintenance perspective.
Some cars still have in-line filters and 30,000 is not bad advice.L.I go 35,000 myself.
IMHO. Stay away from quick oil change place and chain repair shops.
GALVEZE
Engine Mechanical problem
2005 Chevy Malibu 4 cyl Two Wheel Drive Automatic
Where is and how do I replace the fuel filter off my 2005 Chevy Mailbu?
FUEL FILTER
The fuel filter is contained in the fuel sender assembly inside the fuel tank. The paper filter element traps particles in the fuel that may damage the fuel injection system. The filter housing is made to withstand maximum fuel system pressure, exposure to fuel additives, and changes in temperature. There is no service interval for fuel filter replacement.
If the fuel filter is plugged, the fuel tank should be inspected internally and cleaned if necessary.
BUCSFAN5
  • 68 POSTS
  • 2004 CHEVROLET MALIBU
  • 180,000 MILES
Can't find the fuse for the fuel pump. I'm looking at the fuse but what else could it be labeled under other than fuel pump? I need to change the filter as well.
Friday, May 17th, 2019 AT 10:18 AM (Merged)
SATURNTECH9
  • 30,870 POSTS
The fuel filter is in the tank and the fuel pump fuse is under the hood here is a guide to help you change the fuel filter out and a guide to help you test the relay #18 and the location as well
and
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
BUCSFAN5
  • 68 POSTS
The one underneath the hood. I'm actually stumped as 2where the one in the car is cuz it's not in a typical spot.
BUCSFAN5
  • 68 POSTS
So the only fuse I can find is one labeled inj I took it out & it cut off automatically but it was just a 10amp fuse
SATURNTECH9
  • 30,870 POSTS
You pulled the fuel injector fuse the fuse your looking for is in the rear compartment fuse box. Which is located in the trunk its fuse number 25 that is your fuel pump fuse.
BUCSFAN5
  • 68 POSTS
Ahh ha I knew that was there totally 4got bout tht 1. OK well I'm a bit tiny & I'm still having trouble fitting my hands2grab the filter
SATURNTECH9
  • 30,870 POSTS
What filter?
BUCSFAN5
  • 68 POSTS
Haha well I'm changing my fuel filter. Trying 2 tht is. There's only 1 thing I see tht culd be the filter.
SATURNTECH9
  • 30,870 POSTS
Usually the fuel filters on the newer cars are back in the gas tanks.
SATURNTECH9
  • 30,870 POSTS
I just looked and I dont see a fuel filter listed for that car parts wise for sale. Did you actually buy a fuel filter for that car yet?
BUCSFAN5
  • 68 POSTS
Yes I did. What the heck am I doing I wonder haha
BUCSFAN5
  • 68 POSTS
Wish I culd take a pic & send you
