Engine is hard to start?
1995 CHEVROLET BLAZER
312,000 MILES • 6 CYL • 4WD • AUTOMATIC
MACK644
summer months truck starts fine but when it gets cooler out it's hard to start
Sep 18, 2008 at 2:55 PM
  • CAR REPAIR CONTRIBUTOR
Check the fuel pressure fuel pump could be failing, also test the coolant temperature sensor/idle air control valve. These guides will help us fix it
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
and
Please run down these guides and report back. I hope this will be of some help to you.
Sep 18, 2008 at 3:02 PM
DEVOE7
i cannot start my blazer without starter fluid and even then it has poor pickup and stalls alot i have changed the in line gas filter and spark plugs and its the same please help runs good at higher speeds and i hear the fuel pump when i turn the key
Sep 10, 2020 at 12:46 PM (Merged)
Do you hear the fuel pump when you turn key to run-if so check the fuel pressure if its within specs If not check fuel pump fuse and fuel pump relay
DEVOE7
i dont think its the fuel pump because you can hear it on when you turn the key to the on position. like i said i need starter fluid to start the car but then it runs fine idling once i put it in gear it hesitates untill i get it over 15 mph then it runs good especially on the highway and every time it goes back down to idle position , about 800rpm and i give it gas it wants to stall unless i play with the pedal. it cranks fine but wont start without a squirt of starter fluid. someone told me it may be one of thesensors but i dont know HELP ME PLEASE
Sep 10, 2020 at 12:47 PM (Merged)
Test the fuel pump and oil pump sending unit
PETERANDDONNA
  • 23 POSTS
Engine Mechanical problem
1995 Chevy Blazer 6 cyl Four Wheel Drive Automatic 200.00 miles
trucks hard to start when it does got to keep on gas and black smoke out of tail pipe. the screw in egr valve pushes in and out freely any coments thanks peter
BLACKOP555
  • 10,386 POSTS
sounds like the vehicle is running extremely rich.
does the black smoke or running problems go away after the vehicle has warmed up or stay all the time?
i would check out the fuel pressure first, get back to me and well see whats wrong.
PETERANDDONNA
  • 23 POSTS
does not get any better after its warmed up the trucks got no power either seems to be bogging out thanks peter
BLACKOP555
  • 10,386 POSTS
would definetely be checking for fuel pressure, engine off and engien on. see if its getting too much fuel pressure or the injectors are using too much fuel.
ROGER007
  • 38 POSTS
i have a problem with my car if the engine is cold the engine hard starting and if the engine is hot the engine quick start...what is the problem of this matter?
MADMIKE1735
  • 951 POSTS
sounds like loss of fuel pressure.... most commonly caused by a bad fuel spider.... (the main injector) these vehicles have 1 main fuel injector, and 6 injector tubes... 1 per cylinder.... these tubes become brittle, and crack.... then leak.... easiest way to check, is remove your upper intake manifold.... then look for any wetness in your ports of the lower intake manifold.... let me know what you find.
59APACHECUSTOM
Its Hard to start but once it is started it used to start fine ater that. Now it is getting harder to start and keep starting after its been running
  • 110,190 POSTS
Hi:
You need to check fuel pump pressure. Something tells me the pressure is dropping off when the key gets shut. The next time you need to start it, it takes a few seconds to rebuild the pressure.
Here is a how to for checking fuel pressure.
https://www.2carpros.com/dia/test_fuel_pressure.htm
What I need you to pay attention to is when the key is first turned off. I need to know how quickly the pressure drops back to 0 or below 10 PSI.
Let me know what you find and we'll go from there.
TROOPER2005
my blazer as one houndred thousand miles and as of late my chevy blazer has been hard starting if i give it a little gas while starting it chatches but idles rough at frist . i then woke up today and it started fine but now it idels rough and almost stalls so i then started to go to work and stoped at red light n it stalllled and the amp gage was moving down from 14 and back up can any one help me .just had oil change and you can hear fuel pump turn one
Hi trooper2005 and TY for the donation
Clean out the idle air control valve and test the coolant temperature sensor
TROOPER2005
can you tell me were is it located at and i will try that and would that help the voltage as it is not a stady 14 it moves downslowly and back up
What is the fuel system TBI or CPI vortec??
TROOPER2005
it is CPI vortec
STANDING WOLF
Engine Performance problem
car turns over but will not start, if i put starting flued in it , it will start up and run
what could this be
thank you Russ
JDL
  • 16,098 POSTS
I'd check fuel pressure. You need a gage for that. If you have that spider fuel system, it is noted for problems. Hard start, no start after over night sit. The bulletins talk about the poppets sticking.
Once you get it started, does it run and drive ok? My info shows your obd1 so you might be able to check for codes yourself. That might point you in a different direction.
If it is the poppets sticking, you try some seafoam, see if it helps.
95CHEVYBLAZERQUEENS
  • 8 POSTS
Hi, Guys!
I've had this problem before and it cost me a lot so i am being very cautious. Here's the deal my car wont start.Before I would use a starting fluid and it would crank but i had to keep pressure on the pedal. So, I changed the fuel pressure regulator and the car started but then it started to stumble, choking. So, I was told it was the fuel pump. So, got the psi tested and it was at 40 psi. I changed it and the fuel filter still hard starting, idling rough but now the car won't start at all. It sat for three days and i went to start it and it started but I had to keep pressure on the pedal. So, I am totally confused as to what is going on so here are the things I changed.
wires, rotor, distributor, spark plugs was wet from flooding and i cleaned them and put them back in. I changed crank case sensor, fuel injectors was checked with noid light, mapp sensor changed, idle air changed, throttle position sensor changed, except the coil, which was changed like in May four months ago. I also changed the fuel sensor relay.
I also noticed when i was stuck and it let me down i did not hear the ful pump click on. So I banged the tank and it acted like it wanted to turn over but wouldn't even with starting fluid..
I also noticed when the fuel pump was changed the assembly unit hose was a little pinched. So I dont know how much this would effect the psi level. So I bought a new unit but haven't changed it yet.
I know this is crazy but I really want to get to the heart of the matter and solve this problem before I burn the car or push it off a cliff..lol..thanks for your help!
Check your fuel pressure with a fuel pressure gauge and comeback with the actual pressure readings we start here and also you might want to check if the injectors are pulsing and spraying fuel into the cylinders-
95CHEVYBLAZERQUEENS
  • 8 POSTS
I did check the fuel pressure and it was 40 psi. so, I changed the fuel pump 2 days ago and found a kink in the feeder line hose. The car did not start after severl cranks and I think I flooded the spark plugs as before. I think there are two problem and this is one them. But how or where do I gain access to the fuel line to straighten it out? Or should I buy a new line? The fuel line seems to vanish into the car frame from the gas tank.
Also, the next day the car started on the first click? I was shocked. Could be becaus the plugs were wet and the fuel pressure regulator is dumping or leaking fuel? So, should I change the spark plugs and what about the coil? Is there a way to check it with out a tool to see if it is getting enough spark to the plugs? Thanks!
What is your 8th digit VIN??
VIN W the fuel pressure should be 55-61psi
VIN Z " " " " 9-13psi
TB374
blazer will start but i have to keep turning over and shuting off i just replaced fuel filter and i can smell fuel
Sep 10, 2020 at 12:48 PM (Merged)
JDL
  • 16,098 POSTS
Hello, if you have that spider fuel system, I'd check fuel pressure, you need a gage for that. You have good spark at the plugs, injector pulse, during cranking?
If the cmfi system is leaking gas, about all you can do is replace the assembly. I'd try to check everything I could, first.
FIRECATF7
how come I can only use a motor from a 95 in a 95 s10 blazer is there any way around this. I was told once it was because of a extra crank sensor
MADMIKE1735
  • 951 POSTS
whoever said there is an extra crank sensor is sadly mistaken... 1994 was a CPI (central port injected) and was changed in 95 to A two-piece Central Sequential Multiport injection (SFI)... I know for a fact a 95, and a 96 will bolt right up.... ive done it... i believe a 97 will work also.... 98 is a totally different setup, and will not work unless you modify your harness to adapt to the 98 harness..
DOCDAN
1986 Chevy Blazer 6 cyl Two Wheel Drive Automatic
I have been trying to troubleshoot the problems. The Blazer takes MANY attempts to start-almost like the carb is not getting any fuel. Sometimes we have to prime the carb with starter spray or gas, then must allow to warm up well before taking off. When going up a hill-the vehicle repeatedly dies and takes forever to get to the top. This has become a safety concern. I have changed out the plugs and fuel filter. I want to pinpoint the problem. Could this be a compression and/or fuel pump problem?
I was told that the fuel vacuum line could be the problem but still not sure.
  • 110,190 POSTS
Hi:
It sounds like the fuel pump is bad. Have you had it checked for pressure and volume? That is what I would do. If it's good, then I would check for compression.
Let me know what you find.
SHAYLEE
Hi, I have a 1998 Chevy Blazer, approx. 66,000 mi., 4 x4. Recently it has been very slow to start. The engine will crank for a bit before starting. Sometimes I have to try a couple times to get it to start. Additionally, sometimes after driving the car, there is a faint gas smell. Any suggestions are appreciated. If this is a expensive repair let me know, I planned to get a new car in the spring, but I may have to move it up! Thanks! :cry:
E40WATER12
  • 522 POSTS
First off all I would check all youre fuel injectors, For any signs of fuel leaks, Also check pressure at the pump and also injectors, Make sure youre battery fully charged.
