2CarPros - Car Questions & Answers
2000 Cadillac Escalade Repair Question
Topics covered: Door, Wiring, Blower motor.
Asked on June 22, 2010
A/c cooling
Air Conditioning problem
The air conditioning for the driver's cabin does not get cool, yet the a/c for the backseat and rear cabin does get cool.
Avatar Asked by grosas
Answer
Replied on June 22, 2010
Sounds like a possible temp door actuator fault, or HVAC control module. Does it change temperature at all, or does it seem stuck in one position?
Tiny Answered by factoryjack (expert)
4,285 answers provided
The temperature does not change; it never cools in the front, only in the backseat
Tiny Response from grosas
2 questions asked
If you have a voltmeter, and know how to use it, you can reference the following fault chart.
Temperature Actuator Inoperative (FRONT)
Step
Action
Value(s)
Has the HVAC Air Delivery System Check been performed?
Go to Step 2
Go to HVAC Air Delivery System Check
2
Place the ignition switch in the RUN position.
Disconnect the connector at the front temperature door motor.
Connect DMM (volts) between the front temperature door motor connector, cavity 10, and ground.
Is battery voltage present?
Go to Step 4
Go to Step 3
3
Locate and repair the open in CKT 141 (BRN) between the IP fuse block and the front mode door motor. Refer to Wiring Repairs in Wiring Systems.
Is the repair complete?
4
Connect a DMM (continuity) between the front temperature door motor connector, cavity 7, and ground.
Is continuity present?
Go to Step 6
Go to Step 5
5
Locate and repair the open in CKT 150 (BLK) between the front temperature door motor and splice S244. Refer to Wiring Repairs in Wiring Systems.
6
Place the blower switch on the HVAC control module in the LO position.
Make sure that the front blower motor is operating.
Connect a DMM (volts) from the front temperature door motor connector, cavity 8, to ground.
Adjust the position of the temperature control dial while observing the DMM response.
Is the DMM response a smooth, variable voltage?
Go to Step 9
Go to Step 7
7
Disconnect connector C3 at the HVAC control module.
Connect a DMM (volts) between pin 8 of the HVAC control module, and ground.
Go to Step 8
Go to Step 10
8
Locate and repair the open or cause of resistance in CKT 733 (LT BLU) between the HVAC control module and the front temperature door motor. Refer to Wiring Repairs in Wiring Systems.
9
Replace the front temperature door motor. Refer to Temperature Actuator Replacement .
10
Replace the HVAC control module. Refer to Control Assembly Replacement .
I am not sure if the temperature actuator can be accessed in situ, for replacement it shows partial removal of the instrument panel. Here is a view.
http://www.2carpros.com/forum/automotive_pictures/309872_372168_1.jpg
(1) Blower Resistor
(2) Blower Motor
(3) Blower Motor Connectors
(4) C230
(5) C203
(6) C204
(7) Temperature Door Motor
(8) HVAC Plenium
(9) Mode Door Motor
(10) HVAC Wiring Harness
(11) Blower Motor Relay, High
The HVAC control module is the same as the control panel.
