1992 Cadillac Deville
Engine Performance problem
1992 Cadillac Deville V8 Front Wheel Drive Automatic 100000 miles
My mom's 92 Cadillac Deville stops running while it is being driven. It doesn't do anything dramatic, the engine just stops running. She has to put the car into neutral, turn it off, and re-start it while it is coasting.
She says it doesn't happen when she is accelerating.
This has been kind of an intermittent problem, but now, the car won't even stay running long enough to get it out of the driveway.
Thanks in advance for any advice you might offer.
February 13, 2009.
Hey My caddy did this also. Same year 1992 cadillac deville. Pull the bottom cover off. Their is 4 bolts take them out now go to the right passenger side. Look in your owners manuel. Their is a fuse under their for the a/c and the power steering or something like that. The fuse is probably if it does not look bad still change it out. Mine ran ruff the car kept dieing and the a/c would not work. Hope this helps. You could also turn the key to the run spot and hold off and warmer. The computer will doo a bunch of things look at your gas gauge I think. The codes shold be an F or an E with numbers. Write them down post them on here and these guys should be able to help you out. I will try to help as much as I can.
Sep 23, 2012.
