Coolant mixing with transmission fluid?
2007 CADILLAC CTS
144,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
DERRICK GIANAKIS
After car is warmed up, getting it to shift when driving 30 mph is maxing my rpm's. My line from transmission to radiator got pulled out and I noticed the color of the fluid coming out was a coffee with creamer color. I replaced radiator and transmission fluid and filter, filled radiator with water for temporary. Still have same colored fluid in my coolant reservoir and that's when I can't shift out of first or maybe second anymore. I wasn't having a problem I don't think before that line got ripped out. But I replaced it and the fluid and new radiator and can't figure this out. Don't want to pay the dealership. Please help.
Sep 23, 2019 at 12:35 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,350 POSTS
Here is a guide to help you do the cooling system and transmissions service. Make sure you replace the radiator as well the cooler is bad inside.
https://www.2carpros.com/articles/how-to-replace-a-car-radiator
and
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
and
Yep, the transmission does not like coolant inside. but lets run the codes to see if you have a shift solenoid that is not working correctly. Here is a guide to help us:
Sep 24, 2019 at 1:06 PM
GERALE2010
Radiator went out, transmission fluid mix up with antifreeze got inside both transmission and coolant , what should I do to flush it all out
Mar 31, 2021 at 9:50 AM (Merged)
FACTORYJACK
  • 4,159 POSTS
You can flush them out the best as possible, as soon as possible. You may still have transmission issues, as the coolant de-laminates the clutches. Also, you may notice the rubber components of the cooling system sweating oil as it attacks and softens the rubber. Here is a guide to help you do the cooling system and transmissions service. Make sure you replace the radiator as well the cooler is bad inside.
and
and
Cheers
