Mechanics
CRUISE CONTROL
2002 Buick Lesabre
Engine Mechanical problem
2002 Buick Lesabre 6 cyl Front Wheel Drive Automatic 80000 miles
I have a 2002 Buick LeSabre and it has the 3800 V-6 engine with 63,800 miles. The steering wheel has the radio functions on it and the cruise On / Off switch is also on the steering wheel ( bottom Left).
When I push the button to turn on the cruise it will only blink. When I press the same button and the set button at the same time I can see next to the speedometer it lights up the cruise light. Once I release, the small led on the on/off switch goes out and so does the one next to the speedometer. Not sure if there is a short in the steering wheel of if I need to look under the hood at the cruise control module. Either way I still do not know how to fix it.
Any Help is Appreciated
Kidblue
August 18, 2008.
I have a 2001 Lesabre and it does the same thing. If you hold the on/off cruise button, the cruise works, as soon as you release it, the cruise goes off.
If you get the solution, please advise. I will do the same.
AD
76patriot
Aug 19, 2008.
Found the on off switch bad I replaced it now it works fine. Cost $32.00
Kidblue
Aug 19, 2008.
Purchased new switch from rockauto. Com for $23.92 including shipping. Just pry old switch from steering wheel, unplug, reverse procedure and you are on your way. Did the trick.
76patriot
Sep 19, 2008.
AD
