Car stalls when it warms up
KHLOW2008
  • 41,815 POSTS
That could be sometihing to do with the throttle position sensor, MAF and idle controls. Once the stalling is resolved, the problem could be rectified as well.
Thursday, August 30th, 2012 AT 6:35 PM
RMONET2012
  • 46 POSTS
Questions -
1. Can you expand on what to do with the idle controls?
2. Where is the Throttle position sensor located?
Note - I already cleaned the throttle body, IAC and MAF sensor.
Thursday, August 30th, 2012 AT 7:54 PM
KHLOW2008
  • 41,815 POSTS
TPS is the black component with the white cap under the IAC.
Idle controls means the IAC and throttle body itself. These are linked to the engine computer and vacuum leaks would affec them as well.
Thursday, August 30th, 2012 AT 8:14 PM
RMONET2012
  • 46 POSTS
So since I cleaned the throttle body, IAC and MAF sensor, what else should I look at?
What's causing the car to choke and stall when I give it gas?
Thursday, August 30th, 2012 AT 8:21 PM
KHLOW2008
  • 41,815 POSTS
Since you have performance related problems, other than the idle control, the fuel pressure and TPS would be the next thing to check.
Testings of the TPS requires a scan tool.
Thursday, August 30th, 2012 AT 8:38 PM
RMONET2012
  • 46 POSTS
Will a multimeter do?
Thursday, August 30th, 2012 AT 11:46 PM
RMONET2012
  • 46 POSTS
Found this:
The main and only item in the tool list is what is called an ohm volt meter. Once you have identified the TPS sensor, turn on the ignition, do not start the car, make sure the volt meter is on twelve volts DC. Locate the connector that goes from the ECM (engine control module) to the TPS. Once you find this disconnect it completely from the throttle position sensor. There are three prongs; the center prong is usually the negative connector.
Once this is done, take the volt meter and connect the negative side (usually the black wire) to the ground terminal on the battery. When this is done take the positive lead, (usually the red wire) and attach it to one of the other prongs. The volt meter should read five volts, if you are on the reference wire for the TPS. If it reads anything below five volts then you are on the signal wire and need to go to the other prong in the connector. If it reads nothing on the volt meter then you are on the negative connector. Once you locate the reference wire, and it reads five volts then you know that you are getting proper reference voltage to the TPS. Therefore you have just eliminated a faulty power feed to ECM.
Questions:
1. Is this the correct procedure?
2. Are they referring to the car battery?
Thursday, August 30th, 2012 AT 11:50 PM
KHLOW2008
  • 41,815 POSTS
No, a multimeter would not. The procedures are correct for testing the power feed from the PCM, which is required but you need to test the TPS which requires a scan tool.
Yes, the battery means car batttery or any ground on engine would do.
Friday, August 31st, 2012 AT 4:31 AM
RMONET2012
  • 46 POSTS
When I press on the accelerator, the acts like I'm revving the engine and then threatens to stall.
If I let up on the gas, the engine settles back down.
Any thoughts?
Monday, September 10th, 2012 AT 6:12 PM
KHLOW2008
  • 41,815 POSTS
Symptoms are consistent with a TPS fault.
Tuesday, September 11th, 2012 AT 6:29 AM
RMONET2012
  • 46 POSTS
It is easy to change out the TPS?
Wednesday, September 12th, 2012 AT 10:10 PM
RBERQ
  • 16 POSTS
I kind of doubt you have a TPS problem. I think the engine computer relies more on the TPS when the engine is cold, but your problem is after the engine warms up. But here's something easy that is worth a try: Unplug the electrical connector to the TPS and try revving the engine in the way that makes it threaten to stall. If it is no better, plug the connector in again and forget I said anything. If it IS better, try driving it that way, up hills where it usually stalls. If it is like my car, your automatic transmission will shift funny while the TPS is disconnected -- mine would not shift until about 4000 RPM. But if disconnected cures the stalling problem, that's a good sign the TPS is involved.
Wednesday, September 12th, 2012 AT 11:30 PM
RBERQ
  • 16 POSTS
P.S. You said the fuel pressure was checked and was OK. Was the volume also checked -- that is, could the fuel pump maintain pressure when delivering lots of fuel, as opposed to idling or before even starting the engine?
Has ignition timing been checked? (I'm not sure if that is even adjustable with your car, but bad timing could cause problems at higher engine speeds and up hills.)
The puzzle to me is, why did the problem go away for a week after the first shop worked on the car? Did it REALLY go away, or was that just wishful thinking on your part?
Wednesday, September 12th, 2012 AT 11:37 PM
RMONET2012
  • 46 POSTS
No it really was working; I was able to drive it out of state (60 highway miles) with no problems. It ran perfectly for 1 week before the problem reappeared.
Thursday, September 13th, 2012 AT 1:14 AM
RBERQ
  • 16 POSTS
Well, I am not a mechanic so I hesitate to suggest more than what I already did. It sounds like the first garage you mentioned is the only one that did any good for the car. Maybe you can go back to them and say, "You fixed the car but the problem came back in a week". Remind them nicely that you spent a lot of money and don't have any left, and see if they offer to at least check it again to see why their fix didn't work.
Thursday, September 13th, 2012 AT 10:22 AM
RMONET2012
  • 46 POSTS
You're NOT a mechanic? Then what are you doing on this forum giving car repair advice?
Is there anyone there who is, who can help?
Thursday, September 13th, 2012 AT 2:00 PM
RMONET2012
  • 46 POSTS
Please pass me to a certified mechanic.
I tried what you suggested -
"Unplug the electrical connector to the TPS and try revving
I said anything. If it IS better, try driving it that way, up hills"
Result:
1. The engine idle was much higher - stuck in the 2000 range
2. My brakes stopped working - they got spongy and not stopping.
Thursday, September 13th, 2012 AT 4:10 PM
KHLOW2008
  • 41,815 POSTS
When the TPS is disconnected, the PCM is not going to recognise the amount of throttle opening and this would result in it reverting to preset values. Such test do not show you anything.
What you need to do is to plug in a scan tool to test or recalbrate it.
Have you rechecked for trouble codes? Tampering with the TPS would throw codes and it is best to clear the codes and go for test drives first to let the computer relearn and set codes if any are present.
I would still put my money on a faulty TSP.
Thursday, September 13th, 2012 AT 5:51 PM
RMONET2012
  • 46 POSTS
Thanks for taking over. I've seen your profile; are you well versed with Chevy cars?
I do not own a scan tool nor can I take it for a spin because it stalls.
Questions:
1. If I had a scan tool, can it be used with the recalibration?
2. What is the procedure for doing a recalibration?
3. Would it be easier to just change the TPS?
Welcome back
Thursday, September 13th, 2012 AT 6:03 PM
KHLOW2008
  • 41,815 POSTS
I am an arm chair mechanic now and no, I am not well versed with your vehicles. I only work from the information I have and the years of experience with auto repairs.
Whatever information provided is what we work with and if you give us the wrong information, we would get nowhere.
1. Yes
2. The procedures I had shown previously shows how to recalibrate the TPS.
3. Yes, changing the TPS would be an easier option but without any testings, you are only guessing it is the cause and you might be throwing good money on a risk.
Thursday, September 13th, 2012 AT 6:13 PM
