HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Volkswagen
Jetta
Drivetrain
Transmission
Fluid
Transmission Fluid
TAMMYPEAKE
MEMBER
VOLKSWAGEN JETTA
How and where do I check the transmission fulid in a 1999 automatic 4 cyl. VW Jetta?
Friday, July 18th, 2008 AT 10:33 AM
KHLOW2008
MECHANIC
Hi tammypeake,
You need to remove the ATF level plug.
Monday, August 4th, 2008 AT 8:53 AM
CHUTES333
MEMBER
What do the numbers in the picture stand for? If you pull the plug, won't the trans fluid come out?
Thanks for any help
Tuesday, July 7th, 2009 AT 4:05 PM
KHLOW2008
MECHANIC
Hi chutes333,
1 is the plug.
2 is the level tube.
3, is filling tube.
4. Is cap.
Removing the plug ( 1 ) would only allow excess fluid to flow out. To drain you need to remove level tube ( 2 ).
Item 4 has to be replaced if it is removed as it is locked.
Wednesday, July 8th, 2009 AT 8:37 AM
CHUTES333
MEMBER
Thanks for such a quick resonse. You saved me a big headache!
Wednesday, July 8th, 2009 AT 4:26 PM
KHLOW2008
MECHANIC
You are welcomed and glad to be of service.
Have a nice day and thanks for the feedback.
Thursday, July 9th, 2009 AT 8:16 AM
Please
login
or
register
to post a reply.
Related Transmission Fluid Content
1994 Volkswagen Jetta Transmission Fluid In Cooling...
Transmission Problem 1994 Volkswagen Jetta 4 Cyl Two Wheel Drive Automatic 124k Miles I Have Just Noticed That I Currently Have...
Asked by
bones281
1 ANSWER
1994
VOLKSWAGEN JETTA
Where Do I Add Gear Oil To The Transmission. I Can't...
Where Do I Add Gear Oil To The Transmission. I Can't Figure Out Where To Pour It In.
Asked by
maturo
1998
VOLKSWAGEN JETTA
Car Will Jerk When I Accelerate
Four Cylinder Two Wheel Drive Automatic 124,000 Miles. Dear 2carpros: The Car Will Jerk When I Accelerate A Little Bit Hard From A...
Asked by
z1c4y7
2005
VOLKSWAGEN JETTA
2001 Volkswagen Jetta
Transmission Problem 2001 Volkswagen Jetta 6 Cyl Automatic 89.000 Miles I Have A 2001 V6 Jetta. I Have Had It For About A Month And...
Asked by
grnfrk711
2001
VOLKSWAGEN JETTA
Manual Transmission Level
1995 Jetta 2.0 Manual Trans. What Should The Oil Level Be? I Opened The Cap On The Top Of The Case But Do Not See A Level Of Lubricant
Asked by
mannjs
1 IMAGE
1995
VOLKSWAGEN JETTA
VIEW MORE
Transmission Fluid and Filter Ford F-150
Transmission Service Ford Super Duty F-250
Transmission Service 65RFE RAM 1500 2013-2022
