Free Car Repair Advice by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2003 Dodge Caravan Speedometer needle
Posted at Wed Aug 27, 2008 8:56 am |
By
DAN5667,
Have Donated |
Give Feedback | Votes: 0 |
Electrical problem
2003 Dodge Caravan 6 cyl Two Wheel Drive Automatic 62000 miles
The speedometer needle on my Caravan is now below the peg. It hangs down to about the 7 oclock position. When I open the drivers door it jumps up to about 1/16 inch below the peg. When I turn the ignition switch on it moves tight up against the peg. Odometer still works. No warning lights. No other problems. |
Find a
car repair manual for your Dodge Caravan Repair Question.
Posted at Wed Aug 27, 2008 1:21 pm |
By
merlin2021,
Certified 2CarPros Master Technician |
                    (10288) Give Feedback | Votes: 134 |
DIAGNOSIS AND TESTING
DIAGNOSIS AND TESTING - SELF-DIAGNOSTICS
The instrument clusters are equipped with a self diagnostic test feature to help identify electronic problems. Prior to any test, perform the Self-Diagnostic Test. The self diagnostic system displays instrument cluster stored fault codes in the odometer display, sweeps the gauges to the calibration points, and bulb checks the warning indicators. When the key is in the ON position with the engine not running, the MIL will remain illuminated for regulatory purposes.
To activate the Self-Diagnostic program:
1.With the ignition switch in the OFF position, depress the TRIP ODOMETER RESET button. 2.Continue to hold the TRIP ODOMETER RESET button until Sof and a number (software version number (i.e. Sof 3.2 ) appears in the odometer window then release the button. If a fault code is present, the cluster will display it in the odometer display. When all fault codes have been displayed, the cluster will display "end" in the odometer display. Refer to the INSTRUMENT CLUSTER DTC'S table to determine what each trouble code means.
Find a
Posted at Wed Aug 27, 2008 5:56 pm |
By
DAN5667,
Have Donated |
Ran the Trip Odometer Reset procedure. The system ran the cluster calibration and everything is back to normal. |
Find a
Posted at Thu Aug 28, 2008 9:57 am |
By
merlin2021,
Ok great, your welcome.... |
Find a
Posted at Sat Mar 14, 2009 10:50 pm |
By
hty,
New to the forum |
| merlin2021 wrote: | | Ok great, your welcome.... | Hi, i tried your procedure with the reset odometer button, but it didn't work, i have a 1996 chrysler intrepid, is it too old to have that program in it? |
Find a
Posted at Sun Mar 15, 2009 4:41 am |
By
merlin2021,
What problems are you having? |
Find a
Posted at Sun Mar 15, 2009 8:36 am |
By
hty,
New to the forum |
| merlin2021 wrote: | | What problems are you having? |
I replace the battery in my car, then the speedometer needle jumped to the other side of the peg. then i tried to reset the it by pressing the reset odometer button, but it didn't work somehow. what can i do now? thanks |
Find a
Posted at Sun Mar 15, 2009 10:47 am |
By
merlin2021,
QUICK TEST 1. As a quick diagnosis, instrument cluster will perform a function check immediately after ignition is switched to RUN/START position. Electronic display, odometer/transmission range indicator and all warning lights EXCEPT low fuel, cruise, high beam, fog lamps and turn signal will light for a brief period. 2. If cluster is not receiving CCD bus messages, cluster will appear non-functional except for the continuously illuminated air bag indicator, and NO BUS message displayed. If instrument cluster in not receiving CCD bus messages, see appropriate VEHICLE COMMUNICATIONS article. © 2008 Mitchell Repair Information Co., LLC. CAUTION: When battery is disconnected, vehicle computer and memory systems may lose memory data. Driveability problems may exist until computer systems have completed a relearn cycle. See COMPUTER RELEARN PROCEDURES article in GENERAL INFORMATION before disconnecting battery. WARNING: Disconnect negative battery cable BEFORE servicing instrument panel. When power is required for test purposes, reconnect battery for specific test purpose ONLY. After specific test is completed, disconnect negative battery cable before continuing servicing procedures. Page 1 of 1 INSTRUMENT PANEL - ANALOG -1996 Dodge Intrepid 3/15/2009 http://www.ondemand5.com/mric/common/asp/printart.aspx
Should reset by itself when you turn the key to start.
If not it needs to be scanned, but I would try removing the fuse for the cluster and leave it out for a minute and reinstall it, then retry the key. If that doesnt work, remove the neg battery cable leave off for a minute and retry. |
Find a
Posted at Tue Apr 21, 2009 3:47 pm |
By
KarenCaren,
Knows about cars! |
(23) Give Feedback | Votes: 0 |
I think the last instruction will do it. Maybe your odometer receive a sudden jump of electricity. Removing fuse will most likely reset it to its original position.
______________
If you ain't first your last!
dodge performance parts |
Find a
Posted at Thu Apr 23, 2009 10:47 am |
By
merlin2021,
Check the date on this, It's probably fixed, no further reply made usually indicates a successful repair... |
Find a
Goto page 1, 2 Next
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
