Gear shift knob key will not turn all the way?
JOE1953
  • 2004 GMC ENVOY
  • 4.2L
  • V6
  • 4WD
  • 127,000 MILES
When I turn the key counterclockwise it will not go all the way to the left so I can take the key out. So, I want to remove the center console to check the switch under there, but I don't see no screw in the shift knob to take out how do I remove the shift knob?
Saturday, June 21st, 2025 AT 8:22 AM
CANNON1349
  • 864 POSTS
Hello, I will list the procedure for shift lever knob removal below, with a diagram attached below.
1. The floor shift control knob and boot are serviced as an assembly.
2. Loosen the set screw (3)
3. Push in at the base of the boot to release the locking tabs (2) from the console assembly.
4. Pull up to remove the knob and boot assembly from the transmission control (4).
Installation is the reverse of removal.
Hope this helps,
William
Sunday, June 22nd, 2025 AT 6:40 PM
JOE1953
  • 807 POSTS
I don't see no set screw on my transmission control. I wish I could add an Image here, but I don't know how to do it. I do have a picture of my assembly on my phone.
Sunday, June 22nd, 2025 AT 11:14 PM
CANNON1349
  • 864 POSTS
It will be a rather small screw and may be behind a small piece of plastic. After removing this you only need to pull up after disengaging the tabs on the boot.
William
Monday, June 23rd, 2025 AT 4:10 AM
JOE1953
  • 807 POSTS
I found the little screw and I did remove the floor shift control knob and boot assembly and the shift Interlock solenoid, if the solenoid is bad will it cause a stuck key? I can't pull the key out.
Wednesday, June 25th, 2025 AT 8:07 PM
CANNON1349
  • 864 POSTS
No, a bad interlock will prevent you from shifting the gear selector out of Park. If the key is physically stuck in the tumbler you may have a mechanical issue with the tumbler. Does this key have a spring kickback feeling when you turn it to crank? If so what I do in this case is try to "flick" the key by turning it the same way you would when cranking the car but fast enough to let it go and the spring will kick the key back enough to get it out. Sounds weird over the internet, but it has worked for me many times. You might need to disconnect the battery to prevent the engine from starting a bunch of times. If this works we will need to replace the tumbler.
William
Wednesday, June 25th, 2025 AT 8:13 PM
JOE1953
  • 807 POSTS
I think the key does have a spring kickback feeling when I turn it to crank? How do I test the solenoid of the vehicle?
Wednesday, June 25th, 2025 AT 8:40 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,291 POSTS
If you put 12 volts to it, you should be able to see it move.
Saturday, June 28th, 2025 AT 10:17 AM
JOE1953
  • 807 POSTS
The Interlock solenoid have 5 wires connected to it which one I put 12 volts to?
Saturday, June 28th, 2025 AT 11:22 AM
KEN L
  • 54,291 POSTS
It looks like there are two solenoids put 12 volts down the ltgrn/blk and then the drgrn/wht wires and listen for a click or movement. Let me know.
Saturday, June 28th, 2025 AT 11:30 AM
JOE1953
  • 807 POSTS
The solenoid I see is down by the shifter. Where is the other one?
Saturday, June 28th, 2025 AT 12:45 PM
JOE1953
  • 807 POSTS
  • 2004 GMC ENVOY
  • 4.2L
  • V6
  • 4WD
  • 127,000 MILES
Key wont turn all the way off to take it out?
Saturday, June 28th, 2025 AT 1:09 PM (Merged)
CANNON1349
  • 864 POSTS
It sounds like you will need to replace the lock cylinder. I will post the instructions on cylinder removal below with pictures attached. Please let us know if you have any questions about this.
Ignition Lock Cylinder Replacement
Removal Procedure
1. Disconnect the battery negative cable.
2. Disable the SIR system.
3. Remove the steering column trim covers.
4. Turn the ignition lock cylinder to the start position.
5. Insert the tip of an awl into the access hole (1) of the ignition lock cylinder.
(see image 1)
6. Push down and hold the retaining pin of the ignition lock cylinder.
7. Release the ignition lock cylinder to the run position.
8. Remove the ignition lock cylinder by pulling the cylinder away from the steering column.
(see image 2)
William
Saturday, June 28th, 2025 AT 7:21 PM
JOE1953
  • 807 POSTS
Is there a way to check the lock cylinder?
Sunday, June 29th, 2025 AT 3:40 PM
CANNON1349
  • 864 POSTS
If you can break it down to the point where the instructions mention using an awl or pin to depress the lock, you can experiment with the mechanical mechanism on where it locks up on you. If it consistently locks up or it is intermittent, it is definitely worn out. More times than not, the issue you are experiencing is due to a tumbler that has worn out. In this case, you can buy a tumbler and matching key set or have the tumbler and existing key matched.
William
Sunday, June 29th, 2025 AT 3:51 PM
JOE1953
  • 807 POSTS
  • 2004 GMC ENVOY
  • 4.2L
  • 6 CYL
  • 4WD
  • 228,000 MILES
Key stuck in Ignition it want turn all way off the battery is charged and the gear shift is in park why the key want come out? What all I need to check?
Sunday, August 31st, 2025 AT 10:19 AM (Merged)
KEN L
  • 54,291 POSTS
Check everything above.
Sunday, August 31st, 2025 AT 10:20 AM
